Front Axle Seal leaking?
Old Jun 22, 2011 | 06:11 PM
New2Diesel's Avatar
"Gomer Pyle"
My 2000 passenger side axle seal is leaking. Kinda sucks since I just replaced the ENTIRE front steering system and components. How can I fix this, or can I, without ripping the front end apart? Pics of the install or a link would help as well.
Old Jun 22, 2011 | 08:54 PM
biododge1's Avatar
well, Its possible that if your truck is like mine, (and others) you may be over filled in the diff. The level should be about 3/4" below the fill hole and the leak should stop. I know if i fill mine to the hole it leaks
Old Jun 22, 2011 | 09:11 PM
New2Diesel's Avatar
"Gomer Pyle"
That cannot be the case, its been leaking for quite some time. You can tell by the amount of build-up on the hub.
Old Jun 23, 2011 | 09:27 PM
Junk Man's Avatar
AND you want to take the 3 minutes required to find tools & pull the plug to confirm. Checking will also let you know you're not running dangerously low.
That said, there is a nice pictorial somewhere showing how. Someone probably has it bookmarked. It isn't overly difficult but is time consuming. Also, 01 FSM has procedure and is on pdftown.
Old Jun 23, 2011 | 10:06 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
I did that also........Took about 6 months to leak out..Now its ok level..
Old Jun 24, 2011 | 10:38 PM
wlowe's Avatar
http://home.avvanta.com/~n7gxz/Proce..._on_a_2001.doc
Old Jun 28, 2011 | 03:51 PM
dsldan's Avatar
a problem i have noticed on these axels is sometimes the breather vent gets pluged up and the pressure builds up and leaks at the weakest point
Old Jul 19, 2011 | 10:02 PM
farmforever09's Avatar
Mine leaks, like you said before they will leak if they are to full. This also occurs if you park of a hill etc so that it could seap through the seal
Old Jul 20, 2011 | 12:09 AM
rebal's Avatar
you said you had front end work done, did the axles get pulled? if so it could be dirt got pushed on the seal I have been able to pull the shaft and wipe the seal clean and stop the leaks like that
lilsuzuki4x4
Sep 1, 2011 01:50 AM
92smokin blacky
Jan 4, 2011 12:43 AM
t_syverson
Apr 29, 2008 04:25 PM
CCOUGHRAN
Jun 18, 2005 09:13 PM
Copenhagenjunkie
Jul 13, 2004 09:03 AM
