Frieght train
Old Oct 13, 2007 | 12:07 AM
kpeterson's Avatar
Frieght train
My 1998.5 has more motor noise than any i have ever heard, valves are not out of adjustment and i have been using lucas fuel treatment, any ideas
Old Oct 13, 2007 | 07:47 AM
wurkenman's Avatar
If its a 24V, yup they do that.
Old Oct 13, 2007 | 09:33 AM
scout98's Avatar
24V make noise but watch for excessive blowby noise + blowby may = bad piston
I knoow from experince
Old Oct 13, 2007 | 10:13 AM
NoSeeUm's Avatar
I have found that cooler weather makes the engine noisier. The engine should quiet down a bit after it has warmed up fully though.
You might try cleaning your IAT to see if that helps.
Jim
Old Oct 13, 2007 | 09:37 PM
mini14's Avatar
if your timing isnt advanceing due to vp going south that will cauz this too.u live in warm climate soo i dont think the cold is effecting it.mine was at its loudest just before the vp got toasted.
Old Oct 13, 2007 | 10:04 PM
PChouinard's Avatar
Oh great.. I've been noticing some stranger than normal noise in mine as of late.. I must be at the end too.
24V's make alot of racket and they takes some getting used to before you can hear something out of the norm in them.
Old Oct 14, 2007 | 11:32 PM
need12v's Avatar
Before my VP went south I was running an edge EZ and it would make a cyclical rising/falling rattle when going 65-70 down the highway under light loads and about 25-35% throttle. Very weird racket to say the least. I think what happened was the timing portion of my VP failed to the far advanced side and then the EZ threw more timing at it causing a lot of timing advance. Boy would she run like that though!!! I had to put a Comp on it after the VP got replaced to get to the same power level where it would just barely slip the clutch.
Lary Ellis (Top)
55
Nov 8, 2012 10:22 PM
bansh-eman
Jan 4, 2010 09:46 AM
HighTen
Mar 6, 2004 02:49 PM
AKDSLDOG
Apr 6, 2003 08:27 AM
misterKTM
Mar 20, 2003 02:20 PM
