Which fluids for transmission and transfer case
Old Jul 21, 2024 | 11:39 AM
golfpro1's Avatar
2000 ram 2500 4wd with 5 speed.
Ive read that some use 5w30 or gl4 or 75-90 with addition quart or two of atf 4.
and ideas on the transfer case?
Just got a new used old ram and want to change the fluids out before driving it.
If Forrest was still with us id just ask him.
Old Jul 21, 2024 | 03:16 PM
pind's Avatar
I run amsoil MTG in the transmission and Amsoil atf in the t case. Lots of heavy, hard pulling miles, and no problems to date.
also running Amsoil 75w90in both diffs.
Old Jul 22, 2024 | 07:59 AM
u2slow's Avatar
Regular ATF in chain tcases like 241/242. I have no doubt it would be fine with engine oil of similar viscosity.
Not currently running a nv4500, but will do the rebuild with bronze syncros so I don't need expensive snake oil.
Old Dec 7, 2024 | 12:14 PM
NIOMARVIN83's Avatar
For your 2000 Ram 2500 4WD with a 5-speed, here’s what you should use:
Transmission Fluid:
Manual Transmission: You can use GL-4 gear oil or 75W-90 gear oil. Some people also add ATF+4 to the mix, but it’s usually best to follow the manufacturer’s recommendation for your specific model.
Transfer Case Fluid:
Use ATF+4 transmission fluid for the transfer case, unless the owner’s manual says otherwise.
Before you change fluids, double-check the owner's manual for any specific fluid requirements for your truck. It's always a good idea to replace all fluids, including the differential oil, as part of regular maintenance.
Old Jan 8, 2025 | 05:35 PM
SIXSLUG's Avatar
I've stuck with ATF+4 for the life of my transfer case with no issues...remember to get the fill nut out before draining, just in case
My 6-speed gets Pennzoil Synchromesh but the 5 speeds take 75-90 according to my FSM....
Kurt
bradler
Mar 19, 2010 09:49 PM
sheriffav8r
14
Feb 10, 2010 02:01 PM
TigerWebb30
Nov 25, 2009 09:58 PM
coobie
Mar 19, 2005 06:05 PM
