Feels like a pop or something!
Old Jul 26, 2008 | 07:47 AM
jjb3006's Avatar
The other day I was backing out of my driveway, and I then felt a little pop that felt like it came from the back of my truck. I had just previously changed the gear lube using redline. I have checked the U-joints and there is no play with them that I can feel. So I guess that I was wondering if anybody has any ideas as to what may be causing this.
Thanks in advance for any help.
Old Jul 26, 2008 | 08:23 AM
nitrousn's Avatar
If you have a limited slip rear axle did you add the required amount of friction modifier?
Old Jul 26, 2008 | 08:26 AM
nickg's Avatar
not sure if redline has the additive already in the lub for a limited slip diff, likely you will have to add a little additive to keep the diff from making that "pop" thump noise, mine has an additive to but it will make the pop/thump noise almost every time when backing while turning ,then when I go forward and turn at the same time it will do it until I straighten out
I need to add a little more additive...
Old Jul 26, 2008 | 04:40 PM
jjb3006's Avatar
Well yeah I did add some friction modifier when I changed the lube, but maybe I just didn't add enough. Thanks for the ideas
dieselJon
Nov 21, 2007 05:53 PM
973604x4
Sep 4, 2007 08:18 PM
sajigore
Feb 1, 2007 09:38 AM
Geico266
Jul 1, 2005 04:15 PM
gunracer1
May 8, 2003 05:59 AM
