Fass Pump Quick Connect Problem
Old Jan 31, 2007 | 04:27 PM
cuminzman's Avatar
The Disconnect/connect Over My Diesel Tank Was Not A Good Connect. It Was Letting Air In Causing The Pump To Make A Loud Whining Surge Sound. For Two Weeks It Did That And The Engine Died Yesterday . The Pump Sent And Air Bubble To The Ip . Has Anyone Else Had These Problems ?
Old Jan 31, 2007 | 04:39 PM
NotMatt's Avatar
Hmm... I noticed that when I connected mine it wasn't a real solid-feeling connection, seemed like there was some play back and forth in the fitting. However, my FASS pump is pretty quiet... I don't hear it unless I have the door open when I turn the key to on and bump the starter...
Old Jan 31, 2007 | 04:43 PM
sacnvr2l8's Avatar
I've heard of others not using the fitting but claping hose directly to the tank inlet. I didnt have any problems with mine.
Old Jan 31, 2007 | 06:40 PM
Diesel-Dan's Avatar
Most work just fine. BUT if you have some debris or don’t get it snapped up all the way, you might see an issue. Like stated, you can connect the line directly to the tank feed with a clamp....we just added that QD-1001 for convenience. Its supported by o-rings so there will be some slight play in the fittings....its normal.
Old Jan 31, 2007 | 08:52 PM
cuminzman's Avatar
I Clamped It . Works Much Better .
Old Jan 31, 2007 | 11:14 PM
T-BoneAK's Avatar
Broke mine too, so I double clamped it. (not the Clampits ) Much more solid I thought, not that I had a choice.
Old Feb 1, 2007 | 05:06 AM
Rauschbo's Avatar
My QD wouldn't work either, so I clamped the connection, not a hitch since.....
billmac
Oct 5, 2005 02:49 PM
SilverRam01
Jul 27, 2005 11:15 PM
chucktownsend5
Apr 3, 2005 07:53 AM
tony
Jan 11, 2005 10:44 AM
Falcon2005
Dec 13, 2004 10:49 PM
