Factory gear oil for rear diff?
Old Jun 25, 2006 | 09:38 PM
terryKS's Avatar
Have searched but had no luck on finding this. I need to know what is the proper gear oil weight for my rear axle? I have a little oil seeping from my outer axle seal on the drivers side. It seems to be the seal behind the flange held on by 8 bolts. I'm taking a trip next weekend and am going to check my fluid level to be sure I am safe, figure I'll have to add a bit but I need to know what weight to buy. Thanks in advance!
Previous owner used only factory recommended fluids at all times so I just need to know what that is.
Old Jun 26, 2006 | 12:27 AM
J BODY's Avatar
sae gl 5 sae 90 per the good book, but 80-90 was used in the dana 70-80 for a long time too. I run 75-140 synthetic in mine. 1/4 to 1/2 below the fill plug is just fine. If you have the "sure grip" diff and change the fluid be sure to add two mopar friction modifier bottles to the diff.
Old Jun 26, 2006 | 09:20 PM
Tommy93w350's Avatar
I read in a post that if you use Amsoil no additive is needed. Is this true? Also, would you buy a diff gasket or use the blue stuff?
Sorry for the questions, I need to change mine this week.
BAJA MAN
38
Apr 11, 2010 08:06 PM
banana
Dec 1, 2009 11:44 PM
Encryptic
Dec 18, 2004 07:40 PM
mazeppa
Jun 13, 2003 08:17 AM
USMC64-70
Nov 10, 2002 02:59 PM
