exhaust brake opinions
Old Jul 11, 2012 | 07:15 PM
NE frmhnd's Avatar
My boss wants to put an exhaust brake on his 2000 automatic. I'm looking into prices at the moment and want some opinions on the different brands. Pacbrake is looking like a good unit, and appears to be fully plug-and-play, no having to order any other parts with it, which it looks like you have to do with the BD set-up. And yes, I know Banks is over-priced for the results achieved.
He also wants to go to a 4 or 5 inch straight-pipe exhaust. Any particular brands that anyone has had good luck with, and install easily?
Not after a ton more power, just more noise and better stopping.
Old Jul 11, 2012 | 07:41 PM
rebal's Avatar
diamond eye has a good exhaust and we have E brake from just about all of them and pacbrake is at the top, for working good and customer service! but you need to know what exhaust your putting on to determand if you need a turbo mount or inline to fit 4"or 5"
Old Jul 11, 2012 | 08:26 PM
NE frmhnd's Avatar
From what I have seen so far, BD has remote-mount and turbo-mount brakes for 4" tubes. But the turbo-mount has vacuum activation, so we'd have to source a vac pump as well, where their remote mount can be had with a compressor. Then we still need the trans controller. As for 60 pound valve springs, are they needed in the 24 valve, or is that just for the 12 valve?
Though the Pacbrake kit sounds a lot simpler to order, I like the idea of BD's valve body with the 2nd gear lock-up in it.
Old Jul 11, 2012 | 09:33 PM
rebal's Avatar
24 valves all ready have the 60# springs also your truck has vac too, so ether air or vac will work
Old Jul 13, 2012 | 04:59 PM
NE frmhnd's Avatar
I know it has hydroboost brakes, is there still a vac pump on them yet in 2000?
Old Jul 13, 2012 | 05:06 PM
Ed ke6bnl's Avatar
connected to the back of the pump is the vacuum pump
Old Jul 13, 2012 | 08:03 PM
NE frmhnd's Avatar
I haven't looked that close. Same one as the 12v runs?
Old Jul 13, 2012 | 08:28 PM
rebal's Avatar
yes same one
Old Jul 14, 2012 | 03:58 PM
NE frmhnd's Avatar
Had no idea they still had vacuum on the 24valves. Told the boss I like the BD for the transmission upgrades that it can work with, he asked if it was necessary. I told him no, but when the transmission goes out it would be nice to have the option of upgrading at that time. Now that we know about the vac, we will probably go with the BD, thanks.
Old Jul 17, 2012 | 01:10 PM
jthorpe's Avatar
DTR Founder
Give Lary a call at this site's store. He will give you the lowest price possible and he can help you get all the parts you need so you can keep the truck in good shape without messing it up.
In other words, he will tell you the dependant parts you need as not to overheat etc. Good luck.
Sent from my DROID BIONIC using Tapatalk 2
Old Jul 17, 2012 | 01:12 PM
jthorpe's Avatar
DTR Founder
Oh yeah giving you the number might help. 877-375-1956 or you can visit www.dodge-diesel.org
Old Jul 17, 2012 | 05:59 PM
NE frmhnd's Avatar
I guess the boss already ordered it, I don't know who from though. Thanks for the number though, maybe next time.
Old Jul 18, 2012 | 02:03 PM
1998dodgediesel's Avatar
I like the MBRP exaust, it is very strait forward to install, and has good sound.
Old Jul 25, 2012 | 04:29 PM
PaulDaisy's Avatar
BD also makes inline vacuum actuated brakes, I have one in my truck. I went with it because the turbo version comes in a given size and if you ever think of upgrading the turbo, you will need to replace the brake too.
Old Jul 25, 2012 | 08:02 PM
NE frmhnd's Avatar
I think that's what we are going with. The 4 inch inline vacuum. Upgrading the turbo isn't in the plans but who knows, his son is 15, and may end up with the truck someday. But it's not likely. The one that this replaced had almost 300K on it, couldn't keep the front suspension together because of the way it got beat, probably had enough hours on it for another 50,000+ miles because of the stuff we run off the hydra-bed hydraulic remote.
Haulin_in_Dixie
Jul 7, 2023 02:13 PM
Mopar440_6
Feb 11, 2007 10:50 PM
coalburner400
Aug 1, 2006 06:37 PM
2500TurboDodge
Jun 28, 2005 09:52 PM
