Excessive Smoke
Excessive Smoke
I've been having a lot of smoke lately. I'm getting large amounts thru all 6 gears. Obviously the worst is 1,2,3 and 4 but I can also get a lot in 5th and6th just to a lesser degree. The turbo seems very lagging till almost 2k rpm. I'm currently running rv275 injectors and a smarty. The smoke is prevalent across all programming levels. Even on the fuel economy. I'm leaning towards my turbo being worn out. But I'm looking for any help with this. It's killing my mpg!!
By the way, what color smoke are you seeing?
You can check your turbo for sideplay by pulling the intake elbow at the inlet and wiggling the centershaft and see how much play is in it. Make sure the engine is cool when you do this...
I'm running an SO pump but it has never smoked this bad in the 4+ years. I also have RV275 injectors and a smarty on level 5. But it will smoke on any of the levels and seems to get worse on the lower settings.
muddobber40
13
Oct 10, 2006 04:02 PM
robert chilton
Jan 7, 2006 09:42 AM
