Engine Warm up time....
Old Dec 7, 2007 | 05:48 PM
mike4089's Avatar
How long does everyones motor take to come up to temperature...i go out and start my truck every morning at 6:24 exactly and i leave my house in between 6:43 and 6:45...im very precise on times i have the traffic in my town down to a T....but anyway the truck is sitting there idling for a good 20 minutes and the temp gauge has not even moved and i have no heat...and after 15-20 minutes of driving it gets to 190 and the stat opens up....thats a good half hour to forty minutes and it just get to be warm....is that how everyones trucks are???? ps.. im getting my block heater all squared away and working this weekend
Old Dec 7, 2007 | 05:52 PM
JonnyThrottle's Avatar
how cold is it there? I leave mine running till the condensation stops coming out the stacks (about 4-6 minutes) then drive another 4 and can feel the heat starting (about 18* on the coldest morning so far)
Old Dec 7, 2007 | 05:53 PM
P.J's Avatar
P.J
You need to get the idle up at least around 1000. It is really not that great for a truck to sit in cold weather at idle, can cause a number of issues if done regularly.
I have a Pac Brake, that with the factory idle up has me up to 180* in about 7-8 minutes with temps around 30*.
Old Dec 7, 2007 | 05:54 PM
mike4089's Avatar
man...when i start mine up it idles at 800 rpms....what do i need to do to get it to rev at 1000 to warm up quicker....
P.J's Avatar
P.J
Oh, block heater will help dramatically, unless it is just bitter out.
Old Dec 7, 2007 | 05:55 PM
G1625S's Avatar
A CTD will never warm up whil idling. Many will say you can do more harm that good letting it sit for more than 10 minutes. A block heater on a timer (that can handle 20-30 amps) set to come on 3 hours before start time is a beautiful thing. Even without the block heater, I start my rig, allow for oil pressure to come up and drive away. I'm very easy on the loud pedal and try to keep any significant load off the engine untill the t-stat opens. A winter front is helpful and I remove my fan in September, reinstall in May.
Old Dec 7, 2007 | 05:58 PM
P.J's Avatar
P.J
What year truck are we talking here? If it is a 2003/up you can get the "high idle" enabled at the dealer.
Old Dec 7, 2007 | 06:01 PM
wurkenman's Avatar
When I let mine idle at startup, I put the e-rake on and put the truck in drive (of course this only works with and auto). Puts just a little load on the motor. Mine seems to heat up fairly quick.
Old Dec 7, 2007 | 06:14 PM
P.J's Avatar
P.J
Hope you don't come out one day and your truck is missing.....
Old Dec 7, 2007 | 07:26 PM
BigB82789's Avatar
Your tranny temps have got to be skyrocketing!!
Old Dec 7, 2007 | 07:41 PM
P.J's Avatar
P.J
Uh, yeah.
I used to let mine idle in neutral (when I had an auto). Gets the juices flowing, smoother shifts from 1 to 2 and all.
Old Dec 7, 2007 | 09:26 PM
merrillr4's Avatar
My truck always takes a long time to warm up. I recently put on the Quadzilla Adrenaline box and it warms up A LOT and I do mean A LOT quicker. The truck will rev up to 1200 rpm and within 10-15 minutes it is pushing heat.
Old Dec 7, 2007 | 09:29 PM
Hillcountry's Avatar
IF you want a cheap high idle, you can cut a broom handle and wedge it between the seat and pedal. Move the seat forward---higher idle. Move it back---lower. Used to use that in Mass...now that I'm in TX I don't need it.
Old Dec 7, 2007 | 09:33 PM
Bob_24VCTD's Avatar
Does anyone here use the Bra that zippers shut on the front to help trap heat?
Old Dec 7, 2007 | 10:50 PM
mhenon's Avatar
It shouldn't take 15 minutes of driving to get up to temp unless it's really cold. When you get the block heater fixed you'll have heat right off the get-go. I've plugged mine in all night when it's starts getting down in the single digits and it's the only way to go. Diesel engines just love heat!
Mike
