engine temp
Old May 25, 2008 | 09:53 PM
almar.dom's Avatar
Cool engine temp
Please i need help, my truck 3500 1999 , diesel everytime we are in a traffic jam the temperature goes up , i did change the termostate but the only I did fine was for 190 if any one have a link were I can get a lower one I will apriciate.
Best Regard.
PD> live in the caribbean.
Old May 25, 2008 | 10:25 PM
RDMueller's Avatar
Have you cleaned your radiator? The puke bottle on the front of the engine can really gunk up a radiator and lower its efficiency. Most likely the problem would show up first when sitting in traffic due to decreased airflow.
Old May 26, 2008 | 03:39 PM
klx650a2's Avatar
Yes, try cleaning out the rad, here are my after and before pics. To properly clean it out, you have to pull the rad, then move the puke bottle...
https://www.dieseltruckresource.com/...n_fan_side.JPG
https://www.dieseltruckresource.com/...e_fan_side.JPG
https://www.dieseltruckresource.com/...s/fan_side.JPG
Old May 26, 2008 | 06:55 PM
almar.dom's Avatar
thanks, I will try it ..
Old May 27, 2008 | 09:31 AM
neveragain's Avatar
Engine temp
What block # do you have, is it the dreaded 53? My engine time goes up when the coolant gets low. So then just have to add more coolant. A green leaker.
Old May 27, 2008 | 10:46 AM
RowJ's Avatar
Originally Posted by almar.dom
.... i did change the termostate but the only I did fine was for 190 if any one have a link were I can get a lower one I will apriciate.
Love my 180* from Cummins. Runs much cooler in summer and solved my high temp problems at racetrack and in the mountains.
Cummins PN #3967195
I would also make sure radiator is clean, but this 180* T-stst makes a big difference!
Good luck!
RJ
MossyOakCTD
19
Dec 28, 2010 09:11 PM
Racing_Joe66
Jun 12, 2007 05:06 AM
turbox2
Feb 6, 2006 07:44 PM
firesine
Nov 24, 2005 10:58 AM
apache
Feb 22, 2004 05:27 PM
