Engine RPM and overdrive
I have 265/75's and 3.54 gears. When in overdrive, I'm turning about 1900 RPM+/- @ 70mph and when I turn O/D off, I'm at about 2800 RPM @ 70mph. Do these numbers sound about right? I only ask because this truck is new to me, it's my first diesel, and it just doesn't "feel" right in 3rd @ 70mph, but then again, I don't really have any other experience to compare it to.
At 2,800 RPM you are pretty much past the stock usable power band. You are really going to have to lean your foot into the pedal to go.
A Gas motor wil give you a certain % of power as you mash the pedal down, example, 25% of pedal, is 25% power. On a Diesel,, that rule goes out the window. If you hold the pedal down 25%, you get 25% RPM. The Pump Govener takes care of how much power you need. So, at 2,800RPM, it's going to take 75%+ of your pedal travel just to maintain RPM. That would explain why it doesn't feel like it has much more oomph.
Put an EZ box on it and it will really liven it up at lower RPM, increase MPG, and will help your top-end a little.
The top-end could really be taken care of with bigger injectors, or a "bigger" fueling box, but your tranny will make sure you don't do that. (It will need upgraded)
HTH,
Merrick
HTH,
Merrick
jefjsak
Jan 15, 2015 03:44 PM
72demon440
Apr 27, 2007 10:45 PM
fishin fever
Feb 22, 2004 08:32 PM
