engine miss-hicup
engine miss-hicup
Ok guys, I have posted a few questions regarding this issue and finally got it. I had a problem with a miss under light load, almost as if the t/c lock was malfunctioning or the engine had a miss. I went through a IP and two LP's and still no change. Then the other day driving home from CA I had some problems. It sounded like some nylon gears grinding and immediately I asssumed the trans. Pulled over many times and checked it to find nothing. After about 100 miles the brake lamps on the dash came on and I pulled over to check it out once again. Found the right front hub shot, good thing I found it when I did. So anyway I replaced the hub and the miss is gone. The only thing I can figure is the ABS somehow had something to do with it. I hope this is of some use to some of you as it drove me completely insane trying to figure out the miss, not to mention the $$.
steveb
Jun 16, 2003 01:04 AM
