engine knock
Old Jun 22, 2009 | 01:45 PM
dozer12216's Avatar
Impact wrenches are hell on wrong bolts. I recall someone replacing a water pump with longer bolt. Crushed right through cylinder wall and locked piston in place. Talk about a expensiver water pump. You may get lucky on damage.
Old Jun 23, 2009 | 12:07 PM
Honda Hunter's Avatar
Sorry guys, i acyually just got the motor out yesterday and im taking the head off today, so ill let you know later.
Guys on CF are saying i might need a new piston, i sure hope not.
Old Jun 23, 2009 | 09:34 PM
Ok, so the damage is damaged piston, and valve seat. but it looks like the valve itself is ok. the piece ended up in the #6 cylinder.
Old Jun 24, 2009 | 09:17 PM
heres the results.
Old Jun 24, 2009 | 09:34 PM
Tejas TJ's Avatar
WOW!!! Do you know at all how this might have happend, so other people can avoid it?
Old Jun 24, 2009 | 10:16 PM
YES! dont buy banks, and dont over tighten a hair to much on the intake manifold. its fragile.
Old Jun 24, 2009 | 10:20 PM
Checkmate's Avatar
It always seems to be #6.
Old Jun 25, 2009 | 02:25 AM
cumminspower79's Avatar
wow. Did banks give any torque specs with their product? If not i would let them know of this problem.
Old Jun 25, 2009 | 02:27 AM
Also how does the cylinder look? Can you just get by with changing the piston and valves?
Old Jun 25, 2009 | 10:16 AM
the head is fine. and the only things i will need to replace are, the #6 piston, intake valve, and the valve retainer.
As for the banks product, the manifold bolts were very unprofessional for a big name company. they were just long double side studs with a lock nut on the top. Probly from Home depot. But i cant call this on banks because i got the part from a member on CF.
Old Jun 26, 2009 | 10:10 PM
dozer12216's Avatar
Don't be foolish and not replace all valves on affected cyl.
Old Jun 27, 2009 | 12:46 AM
Yah, thanks Dozer. I talked to a guy who will sell me the 4 valves at a good price.
Zee
Mar 23, 2010 09:54 PM
HappyGA
15
Oct 16, 2006 08:21 AM
Hoss
30
Oct 3, 2006 02:57 PM
sinwagon2500
16
Jan 10, 2004 01:34 PM
