engine cuts out under load
Old Feb 27, 2006 | 12:15 PM
gdlukn's Avatar
02 cummins.6 speed.. have replaced apps twice... have hypertech module and 5 in,. exhaust.. runs good without trailer...new fuel filter & replacesd electric pump on side of block. engine surges or cuts out under a load... any suggestions appreciated 168,000 miles
Old Feb 27, 2006 | 02:53 PM
dieselrob's Avatar
Do you have gauges? They help answer most question. Did you check for any codes. Turn key on, off,on, off, on and leave it in the on position. Try that. You might have vp44 troubles.
Old Feb 27, 2006 | 09:04 PM
mini14's Avatar
check codes but sounds like a low boost/map sensor problem possibly if it only happens under a load. could be other problems but first check for codes
DTE
Oct 9, 2014 11:14 PM
Fireman20
Oct 16, 2011 07:12 PM
tch330ci
Apr 16, 2010 08:23 AM
carterw65
Jul 13, 2007 08:34 PM
