Engine block #53...How to tell?
Old Jun 26, 2003 | 02:00 AM
KATOOM's Avatar
How can you tell if you have a #53 engine? If you do what are the issues and what should one do to help prevent any problems? Thanks for the info.
Old Jun 26, 2003 | 05:53 AM
Alan_Reagan's Avatar
Re:Engine block #53...How to tell?
Look on the block just to the rear of the oil filter. The block numbers are stamped/engraved into the flat face of the block there and will start with a 53 or 56.
Sorry I can't remember the issues with the 53 blocks.
Old Jun 26, 2003 | 12:19 PM
turbodiesel_ram's Avatar
The casting number is located on the drivers side of the block, just above the oil pan flange, toward the front of the engine. As a reference point, locate the fuel injection pump while lying under the truck. Look on the block about an inch or so above the oil pan, straight below the fuel pump.<br><br>All of the blocks made after the &quot;53&quot; such as 54,55 and 56 were modified and have no history of cracking. <br><br>Look for coolant leaks coming from the engine and I do not know of any fixes unless your covered under warranty.
az4wheel
Mar 9, 2010 07:40 AM
tufamc
Nov 29, 2006 08:40 AM
plow
Dec 28, 2005 02:42 PM
xp8103
22
Oct 29, 2004 04:22 PM
1320
May 17, 2003 03:28 PM
