53 Block, how to tell?
Old Oct 14, 2004 | 12:40 PM
xp8103's Avatar
Question 53 Block, how to tell?
Yep... another "how to" question.
Old Oct 14, 2004 | 12:42 PM
bob4x4's Avatar
Look at the drivers side of the block towards the front above the pan rail,it will be cast in.
Bob
Old Oct 14, 2004 | 12:53 PM
xp8103's Avatar
pan rail?
Old Oct 14, 2004 | 12:55 PM
phox_mulder's Avatar
Above the oil pan.
Squat in front of the drivers side front tire.
Look on the engine, right above the pitman arm.
I see a "??5K 1" with a big "56" under it.
(?? is behind a wire loom)
phox
Old Oct 14, 2004 | 01:00 PM
xp8103's Avatar
ah... can be seen from the engine bay or do you have to crawl under?
And I seem to recall that by late 2001, the "53" block and KDP were no longer problems?
Old Oct 15, 2004 | 06:41 AM
Tazman's Avatar
Thought I read here there were alot of "53's" in 01. Not sure about the KDP, shouldn't be hard to find a thread
The casting is easy to see from outside the well, no need to crawl under.
Old Oct 16, 2004 | 11:42 AM
OlBlue's Avatar
Here's a pic of a 56 block.
Old Oct 16, 2004 | 06:04 PM
ramtd02's Avatar
stupid question....whats the diff between the 53 and 56 block??
Old Oct 16, 2004 | 06:50 PM
Dr. Evil's Avatar
#53's have thin castings at the water jacket.......they tend to crack much easier and readily than the #56's or the others.
Old Oct 20, 2004 | 07:36 PM
12PACK's Avatar
Were there any 53's for 02? I might go look at an 02 HO and if there's a chance, it will be the first place I'll check out.
Old Oct 20, 2004 | 09:12 PM
Dr. Evil's Avatar
an 02 with a 53 block would be a rareity
Old Oct 21, 2004 | 06:53 AM
xp8103's Avatar
Mine looks to be 28? It's 2-something.
Old Oct 21, 2004 | 07:17 AM
Dr. Evil's Avatar
the casting numbers on a 53 are close to an inch tall and are cast into the block (not stamped) - if you dont see that, you dont have to worry.
Old Oct 21, 2004 | 08:36 AM
wgingg's Avatar
my 01.5 isnt but my buddys "new" 2000 is
Old Oct 26, 2004 | 07:47 AM
2500CTD's Avatar
Ok I dont see any numbers on it like that. Was cold out. Did a quick looky see. So did any blocks come without any numbers like that on them? Or has my block been replaced prior to me? Got the truck used.
