Endless codes
Old Oct 12, 2025 | 02:10 PM
jbpena's Avatar
10 Year Member
Endless codes
Truck has gone into limp mode. Installed a new vp and she was running better than ever I was so happy. Then she began stalling intermittently going in and out of limp mode. The engine sounds loud in the cab when it does so. I check codes and I’ve got
P0216 injection timing control circuit
P0523 oil pressure sensor high
P0236 map sensor too high too long
P1693DTC detected in Companion JTEC
P0230 fuel pump primary circuit
P0500 vehicle speed sensor A
P0602 control module programming error
it’s like everything is going bad from all directions. Is it time for another new ECM? I installed one back in ‘17 that I got from Oliver Foster here. I put in a new Map sensor, new boost sensor and both are either stuck on zero or map on 65 and boost at 50. I get long crank issues from losing prime when shutting truck off especially when off for a while. Fuel pressure is reading great at 17-18psi. I have an edge monitor to be able to see this. Ideas guys. Thanks
gtstrkd
Oct 18, 2010 12:01 PM
danimal 95
Mar 10, 2010 09:08 AM
JD730
Nov 27, 2006 05:54 AM
blong219
Sep 13, 2005 09:59 AM
