End all apps and transmission hunting fixes
Old Apr 18, 2013 | 08:55 PM
chadwick's Avatar
End all apps and transmission hunting fixes?
ok guys, I have had the timbo app for awhile, I am on my second one and looks like I am going to need a third. P0222 showed up and throttle is intermittent and idles very high sometimes. Also from time to time my torque converter will hunt. I have the ATS rewire and the noise filter from geno's on it. Any help will be appreciated.
Old Apr 18, 2013 | 09:45 PM
Tallguy67's Avatar
If you have done both of those - I got nuttin!!!!
Old Apr 18, 2013 | 10:35 PM
Dieselbuilder's Avatar
Check your wiring going to your apps plug as well to the ecm make sure they are clean
Old Apr 18, 2013 | 11:09 PM
SIXSLUG's Avatar
Possibly noise from alternator, have you shielded the wiring?
checked and cleaned all grounds?
Old Apr 19, 2013 | 11:21 AM
Redlinear's Avatar
Once upon a time I had an old CJ5 with a straight six in it. 4spd std.
Start up a hill in 4th and just before you thought it was time to grab 3rd, it'd start bucking (hunting).
Basically, lug it in a high gear and it'd try to throw you out of it.
Motor mounts cured it.
My automatic ctd Ram was doing this same thing. I tried everything mentioned on here to no avail.
Now, this truck had some other problems and, to make a long story short. When I had the engine out, one of the motor mounts was bad. I replaced both.
It doesn't buck/hunt any more, BUT...I changed alot of stuff. So, not sure exactly what cured it.
Had a 64 Impala that acted similar (best I can remember). It would eat carrier bearing rubbers though. New rubber would cure it...for awhile.
Old Apr 19, 2013 | 11:34 AM
SIXSLUG's Avatar
Sorry, just saw you installed noise filter......
Old Apr 19, 2013 | 05:31 PM
chadwick's Avatar
I have 30 ohms to the negative battery clamp on the same side. is that normal Also how do you get the plug for the ecm off
Old Apr 27, 2013 | 09:00 PM
Heimie's Avatar
From: Stony Plain, Alberta, Canada (just outside Edmonton)
I have posted my fix before. I removed every single ground I could find on the truck. Cleaned with a file or emery cloth, added di-electric grease and reconnected. Then I did the same thing with the altenator connections. They helped, but still had a little issue.
Here is the trick that I found, which some people miss:
The A/C connection! It is directly below the oil filter, and gets really dirty. I cleaned that really well with electrical cleaner (smells like brake or carb clean). Added grease and reconnected.
Seems to be the best fix I found. Still had to go through the whole process about once a year, but since the last time it's been almost 2 years. I also added a dedicated ground wire from the TCM (tranny computer on the firewall on the passenger side) housing to the battery. Noise filter did nothing for me.
Hope this helps.
Old Apr 27, 2013 | 10:04 PM
high bid's Avatar
Yep, ck and clean evey ground. Below the driverside battery, pass side fender well ,firewall behind the turbo.....everyone one you can find. The grounds must be clean for this truck to shift and run properly.
mtl0727
Nov 5, 2005 06:47 PM
MrSuzuki
Oct 8, 2005 10:05 PM
MoreSmoke
Feb 14, 2004 08:51 PM
ryker
Sep 23, 2003 09:58 AM
