Emissions?
Old Oct 15, 2004 | 12:53 AM
BDR2500's Avatar
Question Emissions?
I got a notice from the state saying my little stickers on my plates are expiring, so now I have to go get an emissions test. I was wondering if there is anything I should do to help me pass? Besides turning my box off. My D is also striaght piped, so should I put the muffler back on? I thought that with diesels that emissions only had to be done like every 2-3 years. I bought my truck this time last year, the dealer did the emissions for me. So if it were true with 2-3 years, I shouldn't need it till another year or 2. Any help would be great. Thanks
Old Oct 15, 2004 | 03:31 PM
HOHN's Avatar
Just turn your box off. With no injectors, you'll pass for sure. Just make sure then engine is good and warm (NOT IDLING). You also have the small, fast-spooling turbo which lowers emissions even further.
CO diesel emissions are pretty easy to pass. If you have EDMs, you can even run a showerhead injector and still pass, as the opacity is low even with a lot of smoke.
No sweat.
Justin
Old Oct 15, 2004 | 03:40 PM
RowJ's Avatar
I support the "take it out & run it hard" theory...just before having it inspected, if truck not used too often. Can blow out any carbon build up and may help. Also I would not use additives in the tank while being inspected. Sometimes they confuse the tailpipe sensors ( if they use them in your state) by reading high on Hydrocarbons.
Good Luck, RJ
WTTD
Sep 11, 2003 07:44 PM
moneyman
Sep 9, 2003 05:23 PM
Fillerupsonny
Sep 9, 2003 10:29 AM
Campin Johny
Jan 18, 2003 10:48 PM
98rammer
Dec 22, 2002 04:55 PM
