Electrical and trans
Old Jan 27, 2006 | 06:11 PM
Slugblaster's Avatar
4 codes came up Po234 Turbo Boost Limit Exceeded
P1693-DTE detected in companion JTEC module
0753-Trans 3-4 shift sol/trans relay circuit
1765-Trans 12 volt supply relay ctrl circuit
I talked to the guy at Inglewood Transmission and he says to run another ground that there must be a short in the ground somewhere. But he couldn't fax me the details cause his fax is down but ATS diesel,com has the info. Can't find it though. Anyone got any answers or suggestions? I feel like I do when my kids are late getting home. Helpless
Old Jan 27, 2006 | 07:56 PM
firestorm's Avatar
Clean and check all your ground cables. I used the 'star' washers under the terminal ends where they bolt to the fenders. Mine was acting up (droping the torque lock-up and overdrive) after doing mine, the problem went away.
Old Jan 28, 2006 | 10:56 AM
Thanks I'll try that.
merv1
Sep 5, 2012 01:36 PM
mar67655
Mar 17, 2009 07:57 PM
shecom3
Mar 29, 2008 09:48 PM
live wire
Jul 21, 2003 07:26 AM
hbarm01
May 31, 2003 11:59 PM
