EGT's
Old Dec 16, 2002 | 09:10 AM
Hired Gun's Avatar
EGT's
I just recently added gauges and a TST Power MAX 3 box the other day. I will be adding injectors in a few days. My problem is that my EGT's are easily pushed to the max limit. How can I cheaply lower these things?
Old Dec 16, 2002 | 09:18 AM
scottrod's Avatar
Re:EGT's
Try a Scotty II maybe?
Old Dec 16, 2002 | 09:41 AM
pappyman's Avatar
Re:EGT's
Agree with Spark Chaser puttin more cool air in would be cheapest...second would be gettin the exhaust out (straight 4" pipe)
Old Dec 16, 2002 | 02:37 PM
Timinva's Avatar
DTR Advertiser
Re:EGT's
I have the same box and egt problems. My Scotty2 and 4" straight pipe should be here this week, I will post how they do but figure Im gonna need a bigger turbo also . Im running dd3 injectors for now. Tim
Old Dec 17, 2002 | 02:18 AM
Cold Diesel's Avatar
Re:EGT's
Are your 5&quot; stacks 4&quot; from the turbo back to where they go to 5&quot;?<br>I would say you will need the exhaust if you don't already have it, a Scotty 11 with the cowl hole, and a turbo. Sorry but the turbo will be necessay if you want to use the power. I run dd111's, edge comp, 4&quot;exhaust, Scotty 11, and a PDR HX40 and still have EGT troubles in the summer empty. It has to be -10*C before I can stay under 1300* with the fuel all the way up from 0 to 120MPH. I am already looking for more air with this set up.<br>JMHO of course
Old Dec 18, 2002 | 06:15 AM
Kimrey's Avatar
Re:EGT's
How much boost are you creating? It sounds like you don't have enough. You should be able to keep EGT's under control unless your under a load.<br><br>Kirmey
Old Dec 18, 2002 | 07:40 AM
KatDiesel's Avatar
Re:EGT's
You've upgraded the fuel delivery, now you have to add some air, or better quality air. Age old equation of diesel Air + Fuel = Power ...... <br><br>Upgrade the intake, or even consider a turbo change, and if you want to go further, ported head, and camshaft.
Old Dec 18, 2002 | 11:18 AM
BigBlue's Avatar
Re:EGT's
With the BHAF, 4&quot; straight pipe, and comp unplugged, I can hit 1100+ pre turbo, 800+ post. With comp plugged in, I have trouble hitting 700 post. Don't know bout pre. Just moved the probe.
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
Hummin Cummins
Mar 20, 2003 07:20 PM
