EGT Temps and length
Old Dec 6, 2007 | 07:19 PM
granahan378's Avatar
How long can you hold a warm egt? I am talking about towing through the mountains. First trip with the smart set on 5 i was hit 1200 and held it for about 2 mins but did let off of the throttle to keep the temp down what i would like to know is how hot can one go and how long can it be held?
Old Dec 6, 2007 | 07:36 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
1200 is fine for just about any period of time. It's when you start seeing higher temps that I be letting off of the thottle.
Old Dec 6, 2007 | 07:48 PM
glenn-k's Avatar
Yeah, I read 1250 max somewhere.
Old Dec 6, 2007 | 07:58 PM
Thanks guys so 1200 would be okay for say even 5 10 mins on a longer pass?
Old Dec 6, 2007 | 08:01 PM
Mike D's Avatar
Are you still running stock boost levels?
Old Dec 6, 2007 | 08:09 PM
glenn-k's Avatar
1200 should be OK all day.
Old Dec 6, 2007 | 08:16 PM
The boost levels going up the pass ranged from 20 to 26 lbs of boost with a smarty set on 5 with no other mods other than listed in sig
Old Dec 6, 2007 | 08:23 PM
glenn-k's Avatar
4" exhaust and BHAF can both drop your exhaust temps and up your HP. 4 inch exhaust can bring your horsepower up around 28 HP by itself. I went straight pipe. About $250 or so for the pipes so it is cheap horsepower and cuts temps.
You will see the increase in boost pressure when you do the change if you have a gauge. About 10 hp per lb psi boost kind of rule of thumb.
Old Dec 6, 2007 | 09:10 PM
Mike D's Avatar
I forget what you use to modify the wastegate on your year turbo, whether it be a boost elbow or j-hook etc.. You could try to crank the boost up to around 30lbs to see if you get some additional cooling. Personally, I wouldn't worry about 1200 but if you can keep it cooler, then do.
Old Dec 6, 2007 | 09:24 PM
jrs_dodge_diesel's Avatar
1200ºF is the recommended max sustained EGT. You could do 1250ºF sustained, but I personally would play is safe and keep it to 1200ºF.
Besides, keeping reasonable EGT's and going a little slower up a grade is far cheaper than having your pistons do this (thanks to CaptainChrysler for the picture)
Old Dec 6, 2007 | 09:52 PM
that says bad day all over it i wouldnt want that to happen to any one. Guess its time for 4inch exhaust and air intake. Will turning the smarty level down reduce temperatures?
Old Dec 6, 2007 | 10:12 PM
2500Ram's Avatar
It might, try it with just the fuel settings I believe even numbers are fuel only odd numbers are timing and fuel. Obviously if you take it back to stock your egt's will drop but so will your pulling power. I'd look into an exhaust and play with the smarty settings in the mean time. 1200* Pre turbo isn't bad though. I've hit 1350* pulling our TT in the Rockies (short bursts less than 20 seconds) last year, hopefully no problems but after my trans is fixed an exhaust is next.
Good luck.
tuzlo
Aug 11, 2007 02:04 PM
bishgeo
Oct 20, 2005 06:08 AM
BAJA MAN
Aug 31, 2005 08:16 PM
8secondride
Mar 9, 2003 09:27 PM
8secondride
Mar 1, 2003 11:21 PM
