Egt
Old Aug 1, 2004 | 05:25 PM
rattle_rattle's Avatar
Question Egt
Ever since I bought something from 4wheel Parts, I have been getting this mag called Off-Road Adventures. The latest copy has the specs for a lot of Diesel engines. One of the specs from mine is a little confusing. It says the the max EGT is 1250 degrees and the sustained temp is 1050 degrees. Does this mean that I shouldn't run over 1050 degrees for sustained periods? On my trip to Wyoming last month I ran 1200 degrees for hours! It says the source of the data was from manufacturers literature.
Old Aug 1, 2004 | 05:32 PM
phox_mulder's Avatar
Sounds like post turbo temps.
Usually, post turbo is about 300 degrees less than pre turbo.
Add 300 to those numbers.
phox
Old Aug 1, 2004 | 11:51 PM
blueandsilver02's Avatar
that article also said that the common rails have a vp-44 injection pump, is that right??
Old Aug 2, 2004 | 12:12 AM
Smkndzl's Avatar
I look at one everyday , and last time I looked at the CR engine it didn't have one
Old Aug 2, 2004 | 11:12 AM
Old Aug 2, 2004 | 04:51 PM
Nope.
Whomever wrote that article didn't do a lot of research.
phox
Old Aug 3, 2004 | 12:04 AM
well i didnt think so but i havent ever looked one over very close
Old Aug 3, 2004 | 10:05 AM
My question is still...
Will 1200 degrees, sustained temperature, pre-turbo, hurt my motor?
I sure hope not!
Old Aug 3, 2004 | 03:17 PM
BigBlue's Avatar
1250 sustained pre turbo is fine. It's the cummins recommended safety point. You can do quick bursts to 1500. But only for a couple of seconds.
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
Hummin Cummins
Mar 20, 2003 07:20 PM
