Ecm Needed Badly
Old Apr 18, 2008 | 01:40 PM
heinzboz's Avatar
Ecm Needed Badly
After 4 days in the shop, a new alternator, a new lift pump, and a new injection pump, it has come down to my ECM being toast. They were finally able to borrow some sort of machine or tool from a cummins specialty shop that allowed them to bypass the truck ECM, and be run by this machine.
Looks like a new ECM through them is gonna run me $1200. Does anyone know where I can get a cheaper one, or a used one? Its on a 1999 Ford F800, so I don't know if its the same as a regular pickup one or not?? I know the injection pump was different than the pickups. Anyway, the Engine Serial Number is 56555851 if anyone can use that to point me in the right direction. Thanks.
Old Apr 18, 2008 | 01:54 PM
matthopp's Avatar
I went through 2 ECM's in 6 months (scary). Both were new from dealer, luckily they warrantied the second one. The ECM must be flashed by the dealer if you dont get it there.
Old Apr 18, 2008 | 02:27 PM
heinzboz's Avatar
The shop said they saved the calibration so they can program the new ECM. I am just wondering what will interchange with my truck as far as the ECM unit? Wonder if I could use one off of a pickup if it has to be programmed anyway?
Old Apr 18, 2008 | 10:20 PM
johnh's Avatar
here you go http://www.ecm-ecu-online.com/dodge_part_numbers.html
Old Apr 19, 2008 | 08:05 AM
blackdiesel's Avatar
Registered
Not true
My ecm went out and i bought one out of a junkyard and it worked like new
Old Apr 19, 2008 | 11:48 AM
duner's Avatar
that's because it was already downloaded with the engine control software for your truck. most modules ship blank and are downloaded with whatever software is needed to match what it is replacing.
Old Apr 19, 2008 | 04:02 PM
Registered
I under stand that, You just have to get one out of the same truck (same year, same tranny) your putting it in. Mine cost me 200 bucks, and they shipped it from N.C..
Old Apr 19, 2008 | 08:41 PM
heinzboz's Avatar
The issue I'm wondering about is that its out of an industrial truck and not a pickup. I know the injection pump I had to put on it was different than the pickups. Does your ECM have two plug ins on it or just one? Mine has two rectangular plug ins on it. My motor is rated at 190 hp, and I know the pickups are rated for more. I can't find my camera or I'd post a pic of it. Can someone post a pic of their pickup ECM so I can compare?
Eskimo
Jan 31, 2005 08:06 AM
piperca
Jan 25, 2005 05:11 PM
rickyd
Mar 11, 2003 09:16 AM
Shovelhead
Feb 20, 2003 03:16 PM
