Ecm
Old Aug 4, 2006 | 07:42 PM
Phil Crow's Avatar
Ecm
1998.5 24v. How can you tell if the ECM is bad? Is there a test you can do?
Old Aug 4, 2006 | 07:48 PM
phox_mulder's Avatar
What are the symptoms?
Rarely does an ECM go bad.
phox
Old Aug 4, 2006 | 08:11 PM
Bob Wagner's Avatar
first sign is does your WTSL work? (wait to start)
Old Aug 4, 2006 | 10:35 PM
Phil Crow's Avatar
Wts
The WTS light works. It seems to cut off when it gets warm. Has codes p1693 and p1689.
Old Aug 6, 2006 | 04:15 PM
Phil Crow's Avatar
Bad fuel system relay!!!
I found the problem. I had a bad fuel system relay. I switched it out and the truck doesn't cut off anymore!!
Old Jul 20, 2007 | 09:25 AM
leew's Avatar
Where
Where is this relay you replaced located? I am having similiar problems 2 months after vp 44 replacement
ratat98
Sep 18, 2016 07:34 PM
6spd05Dually
Mar 12, 2011 12:19 PM
jrussell
17
Sep 17, 2007 06:38 PM
Ohio Joe
Jul 12, 2004 12:13 PM
