dtt noise filter
Old Jul 24, 2006 | 04:59 PM
reddawg's Avatar
dtt noise filter
what are these and where do i get one
Old Jul 24, 2006 | 08:38 PM
SMOKNISB's Avatar
Some of the trannys have issues with the torque convertor locking and unlocking at highway speeds. It is caused by noise is some of the wiring. You can get them from DTT. Check out this link:
http://www.dieseltrans.com/index.htm
Old Jul 25, 2006 | 05:36 AM
reddawg's Avatar
thanks i will check it out when i get a chance. i am haveing lock up problems
Old Jul 25, 2006 | 06:19 PM
Extra300's Avatar
possible solution
I struggled with this for many months. I installed the DTT noise filter, ran the jumper wire, replaced the TPS, but in the end, what finally and completely eliminated the problem, was simply replacing all the battery cable ends and eliminating all the corrosion. This brought the voltage back up in the system, and i have not had any problems with lock-up since. You might want to try it.
Smkn600CTD
May 22, 2012 07:21 PM
Dieselhed
22
Mar 16, 2009 08:54 AM
ShowMe06
27
Jan 4, 2008 11:47 AM
piperca
Oct 24, 2005 12:56 PM
MoreSmoke
Feb 22, 2004 08:50 AM
