Drivetrain losses
Old May 30, 2003 | 09:39 PM
emjay's Avatar
Re:Drivetrain losses
Do you think that the figures for automatics do not take into account the TCC?
Old May 30, 2003 | 09:59 PM
emjay's Avatar
Well, I don't have an answer for that, but like you said, there are lots of variables, like shaft speeds in the transmission/transfer case, the viscosity of the oil, and for automatics, whether or not the TCC is locked, and the power required to pump the oil throughout. I suppose it could be calculated thermodynamically, but that sounds like a lot of work!
Old May 30, 2003 | 10:25 PM
phox_mulder's Avatar
[quote author=Gary - KJ6Q link=board=4;threadid=15327;start=0#144085 date=1054350500]
Best approach available so far, is comparing what Cummins claims as stock flywheel HP, to what the average stock truck dynos... In my case, my stock HO dynoed at 204 HP at the rear wheels - 20% less than the claimed flywheel HP... Pretty unscientific tho'... And that's with a manual tranny and 2 WD - [/quote]
Well, that's a start.
My non-HO stock 2002 auto tranny 4x4 dynoed at 205 HP.
Two modifications might have scewed that number though,
35 inch tires and no muffler.
I'm thinking about dynoing with the stock tires back on in September for comparison, still with no muffler.
(gonna put them back on for the drag race portion of the get-together, so why not, maybe do both on the same dyno the same day for a real head to head competition)
phox
Old May 30, 2003 | 10:51 PM
DF5152's Avatar
jacobs electronic the maker of High performance ignition systems has book with a whole section on how to determine vehicle horse power without a dyno. it also explain how to determine how much horse power is gobbled up by ur drive train.
Old May 31, 2003 | 12:12 AM
Scotty's Avatar
Top's Younger Twin
My HO 6 spd 01 dyno'd stock at 221<br>its a bit over double that now. ;D
Old May 31, 2003 | 01:14 AM
KATOOM's Avatar
I know that it takes around 50 HP to run a Turbo 400 trans. I was under the impression it took a lot less to turn a manual. The differential takes a lot of power though. I dont think the transfer case takes any real amount of power. All you are doing there is just shooting straight through it. The real drag is having to turn some part of the front driveline while cruising in 2wd.
Old May 31, 2003 | 02:21 AM
HeberRam's Avatar
Gary, where do you come up with these brain busters? I think, you have answered your own question with your truck on a dyno....I have seen, witnessed approx. 400 dyno runs, with various stock trucks on Edges test dyno in Odgen, Utah over the past years, not including events outside. I've seen you take 2 -3 identical stock trucks, all manual or all auto, same dyno sameday, and HP will vary between 10-15 HP, high and low. In one case, a guy had a 25HP difference...Brett at Edge tells me, he'll see that about 1 in 1000 trucks....That's the one you want!!!
On average, 15-20% whether auto or manual, seems to be the power loss from flywheel to rear wheel. I'm not sure if that increases with bombing or not because there are too many variables, and some trucks again perform better then others with the same up-grades ie., injectors, fueling boxes. I would guess, if your trans (auto or manual) does not slip, the same power loss % would be the same as stock levels. I do know the guy that owns the 2000 CDT that power levels &quot;stock&quot; is 25hp more then it should be, and even with his bombing, he has continued to keep that amount of edge over others. I guess sometimes you can get lucky and find that 1 in a 1000.
Steve
P.S. Phox..When we last dynoed at &quot;phantom&quot;, I'm not sure if the the results were after a correction factor, or without a correction factor. At our altitude ( I'm not sure about the exact number) but if the correction factor was say 1.05 then if someone dynoed 200 x 1.05 the corrected HP number would be, 210 HP. I'm not sure if the rear wheel tire size makes any difference on a Dynojet, but at a race track, tire size, width, tread pattern would play a big part in launching. I'll call Larence at Diesel Dynamics next week, and see if tire size afffects HP results? I would love to see you change about 10 sets of tires on a dyno, to squeezeeee that HP.
Besides, your truck is too bad looking to put on some 245x75x16's white walls. 8) 8)
Old May 31, 2003 | 09:05 PM
[quote author=HeberRam link=board=4;threadid=15327;start=0#144141 date=1054365687]
[glow=red, 4, 400]Besides, your truck is too bad looking to put on some 245x75x16's white walls[/glow]. 8) 8)
[/quote]
That said by HeberRam is a real compliment.
Maybe width would be the only factor, as more tire is holding on to the rollers, less slippage perhaps.
phox
Old Jun 1, 2003 | 11:28 AM
HeberRam's Avatar
Phox...my girl friend always said, width does make a difference. As a matter of fact I ran into Danny Waldon in Odgen yesterday, we call him &quot;grampa rabies&quot; because he is a real funny guy and always doing and testing stuff to his truck. Anyway, he did the very samething your questioning Phox, about tire sizes on a dyno and did so on Diesel Dynamics a week ago.. He stepped up 2 sizes from stock (he has a &quot;purple&quot; dually) dynoed before, and after with the new tires and was within 2-3 hp less after the tire change over. Danny's truck is one bad *** &quot;sleeper 12v&quot; doing 545hp on diesel. His biggest obsession, is to beat Dee Rawson, whatever it takes!! ;D ;D Watch-out for &quot;grampa&quot; in a PURPLE dually....
Gary, I can see you won't sleep, until you get your answer.. : : When I call Larwence, I'll see if he can shed some facts to your question..Lawence, has dynoed everything, from sport bikes, lawn mowers, UPS turcks, CTD's, RV's, you name it and if it can spin a Dyno-Jet he's done it.
Steve
P.S. Phox, yesterday I bought a new set of tires, went from 305-70-16 to 315-75-16 , Pro-comp Xtreams. With my 16X8 after-market rims, and a 2&quot;- leveling kit, I thought NO problem!! &quot;Well&quot;, I had to pound the metal on the front wheel- well back panel to death, and now clears maybe a-1/32&quot;. Have to drive straight only, no turns, no bumps , no mud, no snow.... :'( :'(
Old Jun 1, 2003 | 02:51 PM
Bart Timothy's Avatar
I'm thinking that tire size isn't going to affect the numbers as much as tread design, inflation pressures, etc. The best way to test is by using 2 different sizes of the very same tire design. <br><br>Can't you measure driveline losses in the form of heat? That's go to be where most of the loss is going.<br><br>Are we going to see a &quot;Phox&quot; lift job on Heber's truck soon?
Old Jun 1, 2003 | 10:43 PM
[quote author=HeberRam link=board=4;threadid=15327;start=0#144527 date=1054484882]<br>P.S. Phox, yesterday I bought a new set of tires, went from 305-70-16 to 315-75-16 , Pro-comp Xtreams. With my 16X8 after-market rims, and a 2&quot;- leveling kit, I thought NO problem!! &quot;Well&quot;, I had to pound the metal on the front wheel- well back panel to death, and now clears maybe a-1/32&quot;. Have to drive straight only, no turns, no bumps , no mud, no snow.... :'( :'(<br>[/quote]<br><br>Yup, exactly what I did.<br>Got the rims and tires and the 2-inch leveling kit.<br>Straight driving only, really wide semi-like turns.<br>Had to go to the 4.5 inch kit, now turns like a charm.<br><br>I think a 5inch lift would look just perfect on your truck.<br>I suggest either Tuff Country or Mr. Cepek, the skyjacker is a bit harsh of a ride.<br><br><br>phox
