Driveline slip/grab HELP!
Folks I have a problem with my truck and could really use some help. Truck is
2002 CTD 6-speed HO
Current LUK ceramic clutch
150K miles
At about 120K miles I found that I started getting a slip-grab behavior when feeding out the clutch. At that time I assumed that the clutch was going. I had it replaced with a LUK ceramic and found that absolutely nothing changed with regard to this. Specifically as I pull away from a stop as smoothly as possible everything feels OK then BANG, the system catches. There is no level of smooth on the clutch that can eliminate this. I have checked the u joints out but they are fine (replaced anyway) and the rest of the suspension seems OK. I took the truck to a clutch shop and they said that I was getting suspension wind up (think drag racers without torsion bars) and this unwinding was what I was feeling. I don't buy this at all as the unwind is a hard catch. Right now the truck is drivable by me but nobody else really. I am wondering about the rear end (DC stock limited slip) but still suspect the clutch system somehow.
help and thanks for any advice folks can offer.
2002 CTD 6-speed HO
150K miles
IF the driveshaft is ok (check the slip joint on the split shaft) then its time to pull the differential cover. You don't mention having a 4x4, so the slippage isn't in there.
If you don't have any problems in the diff, your trans needs a teardown and inspection.
my guess would be that your fly-wheel is "burnt" and it is hitting that spot, speeding up and then hitting the good part and then "locking" up like it should (resurfaceing the fly-wheel should fix the problem....the shop i worked in always sent them out and had them resurfaced when we did a clutch)....i have also seen ring gears that are missing a few teath, and the pinion is missing about half its teath....but that would cause it to slam all the time. so if i had to point my gun, close my eyes and shoot.....i would say burnt fly-wheel.
additional info
Should have included a couple things I think. My truck is a 4X4 and when the new clutch was put in the vendor said that they turned the flywheel. I can't confirm or deny this. I get the exact same slip catch in 4WD as in 2WD as well as loaded v. unloaded.
thanks for the inputs so far, I will have the slip joint and rear dif inspected. I'm due (actually over due) for new fluids in the dif/tranny/transfer case anyway.
thanks all.
thanks all.
You may want to look inside the clutch slave cylinder. The bore may have a groove in it that is causing the piston to hang up on and not allow the full release for the clutch until you hit a bump or the stress from the engine or tranny cause it to release and Bang clutch engages.
Just my .02
Just my .02
txsmokindiesel
May 19, 2009 08:03 AM
Matt400
24
Jun 21, 2004 03:49 PM
BADodge2003
Aug 24, 2003 07:22 PM
