Drive Shaft Repair?
Old Aug 19, 2009 | 08:03 AM
RowJ's Avatar
Originally Posted by hotdram
Pulled the drive shaft out ..... put truck in 4 Hi and took camper to Ray Roberts SP
Clever! Have not heard of that one either.
Any concern for transfer case after towing camper in frt wheel drive?
Dana 60 worked fine as rear end drive for many yrs.... guess it should work ok on the other end.
RJ
Old Aug 19, 2009 | 08:15 AM
XLR8R's Avatar
That's an Oldie but Goodie - when I blew the spider gears through the diff cover on my '98's D70, I just RTB'd in 4HI... and when someone stole Matt's rear shaft in Bowling Green after we R&R'd a common rail in the parking lot, I told him to cruise back up to PA on the front axle.
Old Aug 19, 2009 | 08:25 AM
RowJ's Avatar
Cooooool!
And the 'Axle Wrap' video is way cool. Definately saved that one to my CTD File!
RJ
Old Aug 19, 2009 | 08:28 AM
bnold's Avatar
Mine only concern running with no rear shaft would be leakage out of the back of the transfer case??
Old Aug 19, 2009 | 08:31 AM
bnold's Avatar
Talk about torque steer! FWD only pulling a 5th wheel! lol
Old Aug 19, 2009 | 10:19 AM
03RAMBUNCTIOUS's Avatar
I watch wind blow...
torque steer. hahahaha.
Saw some trucks at the recent tractor pull that had trac bars up front. They were power jokes with leafs up front.
Old Aug 19, 2009 | 11:22 AM
AggieJustin's Avatar
Originally Posted by bnold
Yikes.. That doesn't sound like anything fun!! Surprised I haven't destroyed one of the 4 on my rear shaft by now... 160k miles and a good number of those pulling 30k plus loads out of pastures! Umm.. surprised Aggie Justin hasn't blown one either then!
Originally Posted by TexasCTD
Do you think the Lazarsmith Traction bars might be playing in a role in their longevity? Course that doesn't explain Justin's good fortune, yet.
Thanks guys...pretty much guaranteeing that I'll destroy one the next time I hang on the trailer.
I usually try to ease into it and through the shifts when loading to avoid putting that initial shock on them. Although this last trip was a little hairy getting out of the pasture onto the highway.
Old Aug 19, 2009 | 11:33 AM
RowJ's Avatar
Originally Posted by AggieJustin
..I usually try to ease into it and through the shifts when loading to avoid putting that initial shock on them.
i'm sure Brian does the same.... who wouldn't. But it's a great point.
That video is simulated drag/sled pulling launch.
New sled pullers (the smart ones) with no trac bars just start out slowly.....
and usually avoid wheelk hop resulting from spring wrap!
RJ
Old Aug 19, 2009 | 12:45 PM
TexasCTD's Avatar
Maybe you could help out Mike's economy a little bit and invest in some Lazarbars.....kind of like a little insurance policy.
Old Aug 19, 2009 | 12:48 PM
TexasCTD's Avatar
Cruising with an empty truck is one thing......but, I don't know if I would feel real comfortable towing....especially heavy towing........in front wheel drive only.
Old Aug 19, 2009 | 01:47 PM
bnold's Avatar
ehh the D60 is a good axle.. sure his foot wasn't on the floor either!
Old Aug 20, 2009 | 08:07 PM
atleast ya'll have options if you lose the rear drive haha.
next truck, next truck. . .
Old Aug 20, 2009 | 09:23 PM
hotdram's Avatar
Just got back from Ft. Campbell KY today and picked up the driveshaft with new u-joints and slip yoke back tonight: $251 out the door. Looks really good, they spray painted it black. Will install tomorrow, top off t-case and rear diff. and see if it works
~Rob
Old Aug 21, 2009 | 02:49 AM
TexasCTD's Avatar
~Rob
Good luck with it Rob. Let us know. Did you get the work done at the place out on 380 just east of McKinney, or someplace else?
Old Aug 21, 2009 | 11:28 AM
hotdram's Avatar
Thanks Robert. Yep, had the driveshaft repaired at the place on 380.
Slapped it in this morning and topped off diff and t-case. Works just fine
I do have a leak in my t-case. Leaking around one or two of the bolts towards the top of the t-case (above the fill port). Since the leak is above the level of the fluid when the truck is parked, I haven't seen it marks it's territory. Wiped everything down, took a spin around the block and upon inspection after that, saw the fluid. Tightened things up and am letting it sit for a while and try again.
When the breakdown occurred, I was less than 10 miles from the camping spot. Dragged the trailer up there carefully, unhooked and took truck back home Thursday night. Used Billie's car to get back from Fri-Sun and had a friend drag me back to storage on Sunday.
Also, I left the slip yoke installed in the output of the t-case, didn't have any leakage
~Rob
Jim Lane
Dec 19, 2017 09:55 AM
Hercules
May 6, 2010 11:43 AM
J_T
Nov 27, 2009 09:09 AM
4x4dually
Jan 5, 2007 01:07 PM
signature600
Oct 5, 2005 01:43 PM
