Dreaded 53 block - new member
Hi all, Awsome site! The past four days on the site have educated me enough to be dangerous (and hopefully ask some intelligent questions).
I'm currenlty looking at a '01 3500 4x4 dually, 5.9 CTD, 5 speed. Its got 140K, had the IP changed at 80K and "the fuel system upgraded by dodge" which I'm not exactly sure what that encompassed - and neither does the owner. He bought the truck with 20K and has owned it since. Its been used for general purpose with a small amount of towing. It also been used to commute about 100 miles each way over a minor mountain pass. This means (at least to me) easy miles for a CTD. It also means its really never been put to work. Am I right so far?
So now for the killer question:
It has the dreaded 53 block. The owner swears its never given him any problems (in fact I helped him to identify it - thanks again guys).
At 140K can this block be pronounced acceptable?
Is there a way to determine if this 53 is a bad 53 or will only time tell?
Do CTD's either give it up early or run forever?
Is it worth $12K to find out?
Thanks for your help,
ClayBob
ClayBob
If its gone that far without an issue, I personally would not worry about it. I've heard rumors that they are warrantied to 160k, some "in the know" will chime in on that. If you're going to make big power with it or tow heavy (who doesn't with the Cummins), I'd stay away. The price seems reasonable. I've heard of LOTS of guys putting many miles on the 53 without any issues...
Fuel system upgraded means an "in tank pump" has been installed, usually a pain in the butt to replace as you have to drop the tank.
Get some gauges, Geno's garage or Vulcan performance has kits, fuel pressure is the absolute first gauge you need...
Before you buy it, check the fuel pressure with a portable gauge during a wide open throttle run. Anything below 5 psi and your injection pump is in danger and those are not a cheap fix...
Welcome to DTR...
Welcome to DTR...
Wow, Thanks for the immediate response. Impressive!
I intend to haul a 3k camper and pull a 5-6K sport fisher. I live in the NW so every direction is up! Is that a lot of weight for a CTD?
Welcome to the DTR!!!!!!
You'll be fine towing that kind of weight, you'll hardly even notice it's back there.
Make sure when you get it you get a fuel pressure gauge! Check for codes with the key trick. You might also have the change the ball joints on it. You'll find out when you get it inspected or you can check them yourself.
Thats not a lot of weight for a CTD, it will make it work a bit, but nothing the mighty Cummins can't handle. I've hauled twice that, just make sure your fuel pressure stays above 5 psi...
6 in row, makes it go...
If you search 53 blocks in the search section you would be reading for days. My truck is a 53. Do they crack? Yes. I used to worry myself to death about it. Any more my thoughts are so what, if it cracks I'll just deal with it. It will be expensive but I had to ask myself this question. How many thousands of 53 block trucks are on the road today? Of course on here you will hear about all the bad ones. There would be no way to figure out a percentage of defective blocks to the number cast because you wouldn't know how many have cracked. I just don't even worry about it, but you can bet that I keep an eye on my res. or any antifreeze smell. As for the price, These trucks are down right now. But me personally, I would pay 12k for a 01 truck that was in good shape as long as the guy could prove it was maintained properly. If he has not done any front end work assume you will be if you want it right
Claybob, that's a tough call. I read a thousand posts on the 53 and researched it very thouroughly and decided I would rather not own one as I tend to stress about that kind of thing.
I also realize there are many other things that I could be worrying about re: my truck including the injection pump, wheel bearings, clutch, tires, axles wipers, door locks, valve stems, power seat heaters, mirrors, window motors etc,etc, etc
But really, if its a nice rig and you're not going to BOMB the heck out of it, it'll probably do fine. The 53's usually crack horizontally along the block wall under the exhaust manifold due to the casting mold dropping a little bit when the iron is poured into the mold, or so it is believed. This causes a slight thinning of metal along the water jackets and cavitation from the occurences of running the engine swirl about this area and eat away at the block creating a weakness after many heat up/cool down cycles that eventually casues the block to crack. Some crack huge while others just hairlaine but a crack is a crack and not good.
You are taking your chances either way but ask yourself if replacing the engine sooner or later is going to wreak havoc on your finances and go from there. Replacing the block isn't cheap but if you got a really nice 2nd gen it may be worth it for you.
You may even be able to use the 53 block as a bargaining chip to bring the price down a little
. Good luck!
Kurt
!But really, if its a nice rig and you're not going to BOMB the heck out of it, it'll probably do fine. The 53's usually crack horizontally along the block wall under the exhaust manifold due to the casting mold dropping a little bit when the iron is poured into the mold, or so it is believed. This causes a slight thinning of metal along the water jackets and cavitation from the occurences of running the engine swirl about this area and eat away at the block creating a weakness after many heat up/cool down cycles that eventually casues the block to crack. Some crack huge while others just hairlaine but a crack is a crack and not good.
. Good luck!Kurt
So, new blocks are about 2K. I know it wont be covered (for the third owner) under any kind of warranty. Playing what if, is the 12K sticker and 2K for a new block still a decent buy (my time for rebuilding is worth nothing - kind of a hobby)?
I've already discussed the 53 with the owner. He's not gonna budge (much) on the price. I really dont want a 3rd gen (just dont like the look). The chances of finding a 98 qc 1 ton seems slim. So, I've either got to grin and bear it (roll the dice on the 53) or buy a Ford (not really a palatable option to me).
I like the 2nd gen qc and everyone appears to indicate its more than enough truck for my needs.
Weren't most of the 2nd gen 5.9's 53's?
98-00 were the years most likely to get a 53 block. Finding one in an 01 is actually a bit of a rarity.
Don't even worry about the 53 block. If it happens, it happens, but in reality, its a very slim chance of it ever happening. You'd be turning down a (possibly) very nice truck on the off chance of a crack. I'd bet its more likely to be totalled in an accident than crack the block. But thats just my opinion. FWIW, I have a 53 in my 24v, it has 400k km on it, been turned up for the last 70, and there is still nothing worng with it.
Thanks all, I'm going to view the truck tonight while its in town. If its in decent shape I'll drive over and cold start it this Sunday, give it a much closer inspection and road test. The current loves his truck and purchased it for the same reasons I'm looking. He seems extremely honest so I'm not gonna be to quick to pass this up. I'll let you know and (hopefully) show some pics of my new rig!
Big Joe
Jul 1, 2005 04:34 PM
zookeeper
Mar 17, 2005 05:27 PM
Rauschbo
14
Feb 19, 2004 10:47 AM
