Dodges new fix for transfer pump
True. But, it is all dependent on where the pressure is being measured. Moving the pump to the tank (like 90% of the EFI gasser currently do) is far easier on the pump. But since most are measuring FP at the end of the (lower pressure portion of the) line, lower pressure at that point would be indicative of lower flow.
Originally Posted by k-bit
The one fact you are not taking into consideration is that a pump is more efficient pushing than sucking. When the pump is move from the engine to the tank the long suction line is eliminated.
So, how is this intank pump an improvement?
We all know that pressure is simply the resistance to flow, right? In this particular fuel system the restrictions that cause pressure are the VP44, fuel filter and lines. Changing the lift pump and relocating it to the tank, the existing restrictions in the system (the VP, filter and lines) remain constant (they did NOT change) regardless of where the pump was placed. The ONLY way to reduce the pressure if the restrictions have not changed is to reduce the flow.....meaning, the intank pump flows considerably less.
Clear as mud?
Clear as mud?
The in tank pump wouldn't be a bad thing if it was in addition to the lift pump, which it apparently is not.
I see I have not been specific enough here! I suppose I should have stated that a displacement pump produces flow, not pressure. I was not considering a centrifugal pump since that was not the type of pump in question. That said, I am familiar with centrifugal pumps and always had a problem with that analogy of producing pressure not flow.....after all, if you cut off 100% flow on the discharge side of a centrifugal pump you would have a high enough restriction to flow that you could say you have no flow and only pressure being produced. It is the idea of putting fluid in motion, or in the case of a 100% restriction, the attempt to put fluid in motion that allows pressure to exist in the first place, no? I am of the belief that the method of pumping is secondary with this analogy.
I have to ask you this, have you ever done a comparison test of the flows? I have and everytime, the in-tank pump flows higher volume. I have never seen less pressure after retrofitting the in-tank pump either. These pumps were designed for stock trucks, not to put up with the fuel demand of heavily fueled trucks.
As to your findings of not noticing a pressure drop with the installation of an intank pump, your experience is clearly an exception to the rule around here and seems to contradict most others first hand experience with the installation of an intank of which I cannot explain.
Physics and math aside, 0 psi wot. is scary. I added a holley blue to the intank asa pusher and my truck loves me for it. These trucks have an appetite for fuel and the intank just starves it. But the physics lesson was a throw back to the days when I didnt pay attention anyway, but it makes sense, The more volume sales pitch is a crock!!!
there are all sorts of HVLP (High Volume Low Pressure) pumps. these two pump are total different in the way they work it is not like taking the old style transfer pump and putting by the tank and running in at a lower voltage for lower pressure if you did this then all that crap about physics would apply. i have a hvlp TURBINE compressor for my spray guns and its output is at 16 cfm (cubic foot per minute) of air and only about 40 psi where as my compressor for my nail gun puts out 6 cfm and about 120 psi and this is running a standard 3/8 hose in both the spray gun and the nailer two totally different compressors and two totally different results. its is the same with the transfer pumps two different types of pumps the hose would only matter if it was way smaller in diameter to make a big enough difference the hose size on the fuel pumps is big enough that it dose make much difference.
there are all sorts of HVLP (High Volume Low Pressure) pumps. these two pump are total different in the way they work it is not like taking the old style trasfer pump and puting by the tank and runing in at a lower voltage for lower pressure if you did this then all that crap about physics would apply. i have a hvlp TURBINE compressor for my spray guns and its output is at 16 cfm (cubic foot per minute) of air and only about 40 psi where as my compressor for my nail gun puts out 6 cfm and about 120 psi and this is running a standard 3/8 hose in both the spray gun and the nailer two totally different compressors and two totally different results. its is the same with the transfer pumps two different types of pumps the hose would only matter if it was way smaller in diameter to make a big enough difference the hose size on the fuel pumps is big enough that it dose make much difference.
I think you might be missing my point....
It does not matter what you call the pump be it a HVLP or whatever.....it does not matter what style or configuration the pump is....and it does not matter what the diameter of the hose is (as long as it stays constant...ie,unchanged). If the restrictions that create the pressure within the system remain constant and unchanged when the pump is replaced, then the only way to experience a pressure drop is because of a corresponding drop in flow (volume).
since i don't really know what I'm talking about when it comes to this updated transfer pump system i did some research and found this site to be very helpful in understanding it.
http://www.glacierdieselpower.com/im...umpExposed.pdf
I love pump debates, CTD NUT is very accurate in everything he's said that I can see........
positive displacement and non-positive displacement pumps are all that I'm aware of.......neither of which create pressure. Only flow. I've never seen a pump create pressure, I've seen loads create pressure, and the static load of actually flowing through the circuit.
I've worked 4 years in hydraulics so far.......I love it. So much more to learn.
i've installed a bunch of these now through warranty and just people upgrading and there hasn't been one fail since. which to some of the guys in the bush up here is a major step forward cause $1200 tow bills suck.
