Did The Tombo Apps Upgrade????
Old Aug 17, 2009 | 07:44 AM
clowndodge01's Avatar
Did The Timbo01 Apps Upgrade????
Well I did the APPS upgrade about a month ago because of TQ converter searching for lockup. The Timbo upgrade helped until, well it started this friday and hasn't quit. Any one else have this problem out there and if so whats the next step? I have done the aluminum foil around the black/orange wire from the alt so whats next other than when Im driving i want to jerk the wheel hard right into the friken ditch
Old Aug 17, 2009 | 07:52 AM
nickg's Avatar
lots of info here
http://www.cumminsforum.com/forum/98...up-thread.html
there still are a couple wire fixes and a noise filter yet for you to try
Old Aug 17, 2009 | 09:19 AM
RowJ's Avatar
DTT TPS noise filter....if you don't have one.....
http://www.dieseltrans.com/dodge/tra...components.htm
RJ
Old Aug 17, 2009 | 10:44 AM
Ill check these links out tonight when I get home my government computer at work has them blocked, thanks for all the input ahead of time.
Old Aug 17, 2009 | 10:49 AM
high bid's Avatar
Clean the gound (-) side of both batts and make sure they are tight!
Old Aug 17, 2009 | 10:56 AM
good point and everything that is posted Im gonna try and thanks again to all that are posting.
Old Aug 17, 2009 | 01:13 PM
jrs_dodge_diesel's Avatar
Here's a free fix : Clean your ground wires.
The effect that is occuring is known as a "ground loop". Ground loop cause unwanted electrical "noise" on electrical and signal lines.
http://en.wikipedia.org/wiki/Ground_loop_(electricity)
Dirty connections, corrosion, and loose connections all contribute to ground loop. Fixing it is easy though. Generally involves cleaning ALL ground connections affecting the transmission and controlling it. Batteries, frame connections and the PCM on the firewall all need to be cleaned.
IMO tin foil shielding and power filters are simply band-aids that mask the underlying problem. And like I said before a simple cleaning with a wire brush and a piece of sandpaper will normally fix the problem with the lockup clutch.
Here is one of my posts from another thread involving the same issue.
Originally Posted by jrs_dodge_diesel
There are 6 key spots to clean. Each negative battery terminal (1,2). There is a wire that runs from each negative battery terminal to the body of the truck with an eye terminal (3,4). Not only did I clean the connector, I took some sandpaper and took the sheet metal to bare metal to give a better electrical connection. The most critical wire to clean is the one on the PCM (Powertrain Control Module) which sits on the firewall, on the passenger side (5,6). The PCM is what controls the lockup clutch. There is a ground wire on it that runs to the firewall. On my truck, I did not like the amount of corrosion I saw on my PCM ground wire, so I replaced it. Made a new one with soldered eye terminals to minimize corrosion. I also sanded the firewall and PCM where the ends connect.
I had the lockup issue and it immediatly was solved after cleaning the gounds.
Old Aug 17, 2009 | 07:28 PM
**** best post yet im gonna do this tomorrow after uncle sam is done at work, thanks again guys you all
Old Aug 17, 2009 | 07:45 PM
Bodean's Avatar
I did the DTT
noise filter and cleaned the grounds. Fixed it. The Dodge place couldn't figure it out but the Forums did!
Old Aug 17, 2009 | 09:47 PM
arcc's Avatar
You may also check your batteries. I used to have a problem, tried grounds and all then found out the batteries were going bad. Put new ones in and the problem went away. Had already done the foil and new ground wire from the computer straight to battery ground. Been a couple of years since batteries were changed. Last week it started searching again. Cleaned battery terminals and no problem since.
Old Aug 17, 2009 | 09:59 PM
dieselcamp's Avatar
I am getting the same grief, I have the Suncoast APPS ground rewire done and that worked, but I don't use my Truck that often only for towing the 5ver and Quads, so the batterys get corroded, but I am going to try shielding the charge wire and install the capacitor as well.
Old Aug 17, 2009 | 10:51 PM
nickg's Avatar
After you clean your batteries try coating the terminals and posts (coat posts before installing terminals) with dialectric silicone, or even wheel bearing grease, the terminals will stop corroding once the terminals are coated
Old Aug 21, 2009 | 09:58 AM
well had the batteries and alt. tested all are good, next step clean the poop outta the batteries and terminals lube up and covered them....result after test drive....RUNS LIKE A CHAMP
Old Aug 21, 2009 | 11:26 AM
Glad to hear you have yours running good again.
sheriffav8r
May 29, 2008 06:47 PM
Mexstan
Aug 27, 2004 09:37 AM
MoreSmoke
Feb 14, 2004 08:51 PM
