A decrease in fuel mileage????
Old Jul 8, 2007 | 11:42 AM
jeasen's Avatar
Question A decrease in fuel mileage????
It is a 2002 2500 4X4 with a 5-speed. It has a Bully Dog Torque Dog chip, cold air intake, boost gauge and lift pump pressure gauge. Mileage is down about 3 MPG?? Truck is pumping out black smoke when accelerating. It takes more boost to accelerate in traffic. I also can almost zero out the fuel pressure gauge when accelerating. Fuel filter has less than 2000 miles on it. Did I get a bad tank of fuel that plugged the filter??? Any ideas what is going on here??
Jeasen
Old Jul 9, 2007 | 12:44 PM
jeasen's Avatar
Ideas?
Ideas anyone?
Old Jul 9, 2007 | 01:12 PM
blackdiesel's Avatar
Registered
Welcome to DTR, check for codes with the key trick on, off on off on, and watch your milage.
Old Jul 9, 2007 | 01:25 PM
Mike D's Avatar
Things to look for:
Boost leaks
IAT sensor
Codes
Old Jul 9, 2007 | 07:08 PM
jeasen's Avatar
Codes
Thanks for your help. I did the on, off, on,off, on thing and these were the codes that came up: PCU 1693, Ecu 0236. Now what do I do?
Jeasen
Old Jul 9, 2007 | 07:15 PM
jeasen's Avatar
codes
I would have done a search but the site will not let me. How do I reset the codes? I see nothing that looks like a boost leak and my boost gauge goes right up as always. Maybe I should not have got so upset with this guy and should not have smoked him. I am new here but not new to diesel trucks. I just want to get this truck back to normal. All help is appreciated.
Jeasen
Old Jul 9, 2007 | 11:41 PM
whiskeyrichard's Avatar
accoding to the manual that came with my smarty, the codes mean this:
0236 ---> map sensor too high tooo long
1693 ---> dtc cleared in companion jtec module
now, you'll have to find somebody to explain what that means
WR
Old Jul 10, 2007 | 12:42 PM
Mike D's Avatar
The 0236 code is probably coming from the bullydog.
I would worry about the lift pump with that kind of fuel pressure.
Old Jul 10, 2007 | 01:01 PM
hamilton71801's Avatar
I was getting 0237(Map Sensor too low) so I took off my programmer and was still getting it. I cleaned the IAT sensor and Map sensor but it still kept coming back so I just replaced the Map and haven't had any troubles since. Take your bullydog off and see what happens.
TxDiesel007
14
Aug 12, 2014 05:18 PM
jlandry
Jun 24, 2011 03:25 PM
imbodie
Sep 17, 2008 01:50 PM
joe22790
Jul 9, 2007 11:04 PM
chadrock
May 21, 2004 04:38 PM
