dead '01 3500 4X4 but has fuel pressure
Old Jan 31, 2009 | 10:40 PM
fryerdiesel's Avatar
OK, I bought an '01 3500 with 231,xxx miles on it from an auction. Dumb, I know, but now I tow the thing home, put 2 batteries in it, crank it over with a fuel pressure gauge on the lift pump and I'm getting like 5-10 psi so no problem there and I have no codes. Now there were some when I first hooked the scanner up but they were just stored. Nothing current. However, this thing doesn't sound right to me when it's cranking so I want to check the engine. I have a Dodge factory repair manual but it says nothing about a compression test. Do I pull the injectors to do that?
Old Feb 1, 2009 | 12:05 AM
BlackRam1's Avatar
did you try cracking open an injector line to check for air?what were the stored codes? not sure about pulling the injectors but I would think so. will check my hayes manual when i find it.
Frank
Old Feb 1, 2009 | 07:45 AM
nickg's Avatar
Checking at the lift pump is a bad idea, checking fuel pressure at the VP, is better, how and where did you hook up the pressure gauge? If at vp ok, if not check at VP (filter is between VP and LP could be plugged)
Try cracking banjo bolt at VP to bleed all air from the LP to the VP. (manually wire the LP to run all the time if you have too or keep "bumping" ignition to keep the LP running it will run 15-20sec if you bump the key.
Once you have fuel with no bubbles leaking out of the VP inlet. then loosen 2-3 injector lines at the head, and crank the engine, sometimes it will catch with the lines loose sometimes not, crank 10sec or so at a time , till you see fuel. then tighten lines engine should start and run, if not then you have other issues, bad VP, wiring etc
The old stored codes would be helpful in helping to diagnois your problem
Old Feb 1, 2009 | 05:41 PM
OK, yeah. I meant the lift pump puts out about 10 psi or so. Sorry about that. I'm checking it at the output of the lift pump where it goes to the injector pump. The codes were: P1698, P0562, P0230, P1693 and the dreaded P0216 was in there but I thought it would've come back after I erased them if the injector pump was bad. Not true?
Old Feb 1, 2009 | 09:42 PM
bobem12's Avatar
sounds like a dead vp to me. when mine went I had a couple of the codes you listed
Old Feb 1, 2009 | 09:49 PM
nickg's Avatar
try this link
http://www.bluechipdiesel.com/vp44diagnostichelp.html
Old Feb 2, 2009 | 08:21 AM
dozer12216's Avatar
Do as NICKG suggested. Be prepared for VP44 replace. Codes will not resurface during cranking. Has to have run history to generate most codes.
Old Feb 2, 2009 | 08:39 AM
OK, thanks guys. I'll take your suggestions and if all I have to do is replace the VP44 I'll consider myself lucky since an engine replacement would be a much bigger pain for me.
Old Feb 3, 2009 | 08:15 AM
Cracked 3 high pressure lines, watched while engine was cranking and only one had any fuel coming out so now I'm looking for a pump.
Old Feb 3, 2009 | 02:21 PM
thumper549's Avatar
I am getting smarter at this (unfortunately )
Did you get the codes ??
Because you have NO fuel there does not condemn the pump ! couple more checks are in order 1st
Hagios Dewet
Dec 2, 2014 12:35 PM
600 Megawatts
Mar 26, 2008 07:09 PM
V.R.Wheeler
Aug 4, 2007 01:00 PM
jtalaiver
20
Jun 22, 2007 10:36 AM
b.white
Mar 20, 2007 05:28 PM
