Cracked Yoke...
Old May 7, 2010 | 07:08 PM
ellerman's Avatar
Cracked Yoke...
I've been hearing a little bit of u-joint noise when I shift gears so I crawled under my truck to check out the u-joint on my rear end and discovered my yoke is cracked. I'm wondering if anybody can confirm if the pinion has shims or a crush sleeve? If it's shimmed I may buy the big socket and try the repair myself. Any suggestions?
Also, I'm surprised that the yoke is cracked because I don't do burn outs or drive my truck hard.
Old May 7, 2010 | 08:46 PM
nitrousn's Avatar
The pinion preload is by shims. So you can replace the yoke and seal.
Old May 7, 2010 | 11:20 PM
ellerman's Avatar
Thanks, looks like I might do this repair myself.
Old May 8, 2010 | 08:53 AM
2002-5.9's Avatar
This may help:
http://www2.dana.com/pdf/AXSM-0053.PDF
klx650a2
Apr 20, 2009 05:25 PM
dieselcarpenter
Sep 18, 2007 06:01 PM
Billk
Jul 7, 2003 10:56 PM
WVPANHANDLER
Feb 1, 2003 08:23 PM
1stGenBikeHauler
Jan 25, 2003 12:31 PM
