CPS Location
Old Sep 12, 2007 | 03:51 AM
opie744's Avatar
CPS Location?
Thanks to all the useful threads on this board, I've come to the conclusion that my crank position sensor is bad in my truck. The only thing that I cannot seem to find is where exactley it is located. Ive read both at the front of the motor and behind the starter. Can someone narrow it down for me? Thanks in advance.
1999 2500 4x4 5.9 24v
Old Sep 12, 2007 | 04:37 AM
george7941's Avatar
The crank sensor is behind the starter and the cam sensor is at the front of the engine, behind and underneath the VP44 pump. You probably need to replace the crank sensor since it is the one that normally gives problems.
Old Sep 12, 2007 | 04:50 AM
opie744's Avatar
I already own the new one. Thanks for the help.
Old Sep 12, 2007 | 11:41 AM
bentwings's Avatar
Be sure you look down the hole with a mirror at the 'tone ring' . If the old CPS is gouged up on the end you may have a loose tone ring. Read...rather larger problem.
dogfish
Oct 31, 2010 04:28 PM
59FORD
Apr 7, 2006 12:28 AM
John In NC
Oct 22, 2005 09:14 AM
z1bigtom
May 28, 2004 05:02 PM
BigBlackDodge
Mar 16, 2003 09:04 AM
