Cpl number on the cummins engine tag
On the cummins engine tag, which one of the numbers is the CPL, what does cpl stand for? I found the tag on the block now problem, just having hard time figuring out which one is the cpl number, thanks for the help
For those who don't know what it is, CPL stands for Controlled Parts List. It is a parts list that is specific to that series engine and configuration. Remember that the 5.9 comes in several different varieties. The CPL is hte number a mechanic or parts guy will use to get the right part for that engine configuration. Things like heads, injectors, valves are configuration specific. To find the CPL nuber look on your engine at the front drivers side of the timing case. There is a data plate with lots of info. CPL is listed in there.
Originally Posted by CTD2001
Thanks for the info and saying what CPL stands for
The other number to keep handy is the 8 digit engine serial number. Cummins Southern Plains in Houston is right around the corner from my office and any time I need parts, the guys at the parts counter ask for the sn.
Check this out. This is what the the data plate looks like. Yours may be buried under grease buildup, especially if you still have the stock breather bottle setup. Firing order is also on the plate under the CPL #. 1 5 3 6 2 4
Grider Pirate
Mar 15, 2009 10:37 AM
Bushy
Jul 16, 2005 01:50 PM
steelydan
Oct 25, 2004 10:06 PM
