Couple Block issues. Advice would be very helpful.
Old Sep 14, 2009 | 08:04 AM
77machomopar's Avatar
Originally Posted by dozer12216
I would think a decent machine shop could build a fixture and transfer the hole to old block.
Say start with a tube that fit the crank sensor hole. Get another tube(pipe) that fit over that tube. Build a bracket located on oil pan holes. Weld second tube to bracket that has been extended upward. Use bracket and 2nd tube as fixture on 12v block and drill appropiate hole. Some precision required.
Will the 24v crank fit a 12v? Look and measure before you jump. Are there additional variations in the blocks? Definitelly Yes!! So look and measure ten more times. Any luck finding a 24v bare block????
I am going to test fit the 24v crank tonight to see what variations there are. Hopefully i can make something work. I would really like to jsut use the entire 12v bottom end but this darn sensor is keeping me from that. No luck with a 24v block. thanks keep the ideas coming
Old Sep 15, 2009 | 06:53 AM
Alright guys i talked to a very reputable diesel performance shop yesterday and they said the 24v crank wont fit in a 12v block. SO... what do i have to do with electronics to make everything work properly with a 12v engine?
Old Sep 15, 2009 | 09:16 AM
biododge1's Avatar
See my Posts!!
p.o.s.
Dec 20, 2008 02:59 PM
bws
Apr 1, 2005 07:36 AM
kelley15
Jan 12, 2005 08:18 PM
dionysius
Oct 22, 2003 08:25 PM
twintracks
Jan 5, 2003 08:10 AM
