coolant leak
Old Jan 10, 2004 | 08:43 AM
primepedaler's Avatar
coolant leak
Here's the problem- 2001 HO w/6 speed has developed a coolant leak. Drips off of the bottom of the bell housing. Looking at the engine from the top I can see a coolant trail coming down the drivers side of the block somewhere from the top but the engine is set so far back under the firewall I can't see exactly from where.
Only leaks when running and leaks about a quart a day running.
Had the clutch changed recently and I don't know if they messed something up. No apparent hose leaks.
Anyone know if there are freeze plugs back there or hoses that I can't see from the top?
Appreciate any input.
Old Jan 10, 2004 | 11:00 AM
gcssr's Avatar
to start , I would check the block for # 53 casting; if # 53 ,do a search other than that give more info. and somebody can help.
Old Jan 10, 2004 | 11:17 AM
thumper 549's Avatar
There is a cam plug and a oil gally plug in behind the bell h. so......yea check your 53 # and then I would suspect head gskt /cracked head (common if overheated or abused)
btdtgtts
Old Jan 14, 2004 | 08:18 PM
sully's Avatar
I've got the dreaded # 53 block in my 99 dodge 24v ! i'm in the process with Cummins dealer for a replacement because of a cracked block. i only got 113,900 miles on mine. If this is your problem you need to get ahold of Cummins Inc. and let them know your problem and i believe they'll help you out some ! Hopefully , good luck , sully
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
george7941
Nov 28, 2009 09:28 PM
Mark Hodowanec
Aug 17, 2009 11:56 AM
popeyesides
Dec 6, 2004 03:43 PM
