Coolant
Old Apr 21, 2003 | 11:07 AM
hellotbone's Avatar
Re:Coolant
I would run it and fill the rar to bleed the air out then elevate the front end to get the air to work its way out the highest point the rad cap
Old Apr 21, 2003 | 11:17 AM
PourinDiesel's Avatar
Re:Coolant
You also might not have drained the engine completely.<br>Sometimes its hard to get all 6 gallons out.<br><br>I would do what Jamie says, monitor your temps and let the air run out of the engine.<br><br>--Justin
Old Apr 25, 2003 | 12:24 PM
EricBu12's Avatar
Re:Coolant
Did a drain, Hooked a flush kit to the heater hose, back flushed it til clear water, drained it, then I used a compressor nozzle to blow the coolant out the heater core and got about 5 gal of 50/50 in......did a coolant test and the blend is down a bit because of the water that was trapped in the block......<br>Going to maybe next year, drain a gal and put it back from the new gal I have to bring the % back up.....
Old Apr 25, 2003 | 06:47 PM
Stamey's Avatar
Re:Coolant
With pretty much any engine you will have an air lock behind the thermostat until it opens. Run the engine untill it gets to operating temperature and you will be able to get the rest in. If this is not possible to do in the yard, take it out for a spin around the block. If you refill immediately be extremely careful removing the radiator cap after riding around the block. While it should not have built any up, there may be pressure on the cooling system, depending on how big your &quot;drive around the block&quot; is. : You may want to just put it on there but not tighten it. This was any overflow will not just spew out, but will go into the overflow tank.
Chris
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
Mark Hodowanec
Aug 17, 2009 11:56 AM
popeyesides
Dec 6, 2004 03:43 PM
Fillerupsonny
Oct 8, 2002 01:22 PM
