conv will not lock up
Old Nov 18, 2007 | 07:12 PM
biff426's Avatar
I replaced the torque conv with a tci unit this weekend as well as replaced the filter and pan gasket got it back together and the trans shifts fine but the conv will not lock up I checked the pid with my snapon scanner and the tcc selonoid is commanded on but no dice I also did the selonoid test with the engine off and can hear the selonoid click is the conv junk???? I replaced the conv because tci claims better fuel economy everthing worked fine before
Old Nov 18, 2007 | 08:36 PM
oldblues's Avatar
hi
is the trany full of fluid ? checked in N engine running and after slowely shifting to all gears slowely !
does it feel like the rpms are any lower than befor / less slipage ?
what fluid did you use ?
do a preasure test with a gage !
Old Nov 19, 2007 | 03:26 PM
biff426's Avatar
Trans is full used atf+4 didn't change anything other then the conv and filter /fluid
perkins
Cummins Conversions
76
Oct 20, 2015 06:23 PM
Capp35
Feb 22, 2009 09:17 AM
tonitto
14
Dec 21, 2007 06:35 PM
belgianmagic
15
Aug 15, 2007 02:37 AM
mkrenn
22
Feb 26, 2005 08:25 PM
