common sqweek
Old Sep 21, 2009 | 07:24 AM
coon-dog7070's Avatar
common sqweek
since i bought my dodge in febuary i have the sqweek when i turn the motor off. does anybody know what it is? i think its the belt. any help would be appreciated
Matt
Old Sep 21, 2009 | 07:28 AM
Doj Dewd's Avatar
it's the belt - i believe the fan stops turning a tad after the crank - causing the squeak.
if not, i know it's something along those lines because when i remove my fan in the winter the 'shutdown squeak' goes away.
don't worry - this is a perfectly normal sound you are hearing.
Old Sep 21, 2009 | 07:49 AM
77machomopar's Avatar
yep its normal. not all trucks do it though. i know mine did till i changed the belt. then it stopped
Old Sep 21, 2009 | 08:27 AM
ericg's Avatar
yeah mine did it too the motor stops faster than the accessories,i changed my belt to a goodyear belt and it stopped {if it bothers you}
Old Sep 21, 2009 | 09:03 AM
ldornak's Avatar
Perfectly normal as explained above. When I changed my belt, the squeek went away for awhile, but now it's back. If it bothers you, I hear that gatorback belts are best for eliminating the squeek.
Old Sep 21, 2009 | 10:37 AM
dozer12216's Avatar
normal belt squeak
As above. It is the alternator rotor interia that causes squeak. Engine stops on a compression stroke whenshut key off and compression tends to push crank backwards. This sudden change is more that belt can hold. The other cure is install a later model pulley that incorporates a one way clutch. Mini vans were the first to use if I recall. It saves fuel also.
Old Sep 21, 2009 | 10:56 AM
DIESELWRKS's Avatar
IMO gator back belts dont always cure the problem I have one now with 7 months on it and its making noise just like the other cheaper ones. just a sound but not all the time. just check your belt if to you it looks like it needs replaced. crackes and etc. then do it. if not dont worrie.
Old Sep 21, 2009 | 11:24 AM
thanks guys i appreciate it
doomgaze
Mar 26, 2003 05:36 AM
spots
Mar 18, 2003 07:14 PM
Berak
Feb 10, 2003 08:48 PM
Oct 29, 2002 03:15 PM
