cold start heaters coming on at 65 degres
Old Mar 4, 2012 | 04:08 PM
GUY1996's Avatar
need help. on 2001 dodge ram with cummings engine the cold start heaters still come on when the outside tempeture is 65 and the cycle last for 2 minutes this is a great discharge on battery. are there a adjustment to set the actavator to a lower temp. to avoid this battery drain.thanks fromGUY1996
Old Mar 4, 2012 | 06:39 PM
RacerRon's Avatar
Not adjustable. I just start driving. When you hit 19 MPH the grid cycle will stop.
Sent from my DROIDX using Tapatalk
Old Mar 4, 2012 | 07:33 PM
06RAM2500's Avatar
You can unhook the cable that runs from the solenoid to the heaters. The relay will still come on, but there won't be a load on the other end.
Old Mar 5, 2012 | 10:49 AM
SIXSLUG's Avatar
Mine will do this also.
Stock batteries lasted for 10 years so I didn't worry about it.
Not sure if IAT has anything to do with it but maybe try cleaning it and see if it helps.
Old Mar 5, 2012 | 10:35 PM
Thundercraft's Avatar
with all of the above statements.
The IAT sensor is the trigger.... It might be 65 when you go to fire it up, but it probably was a lot cooler during the night... all of that metal is still going to be cold... as soon as the engine fires up, the intake air is cooled by any cold metal it touches.
pmtg
Feb 10, 2015 07:00 AM
bullfrog5.9
Jan 3, 2010 05:41 PM
ollie32
Jul 16, 2009 05:02 PM
Rednecktastic
35
Nov 12, 2007 06:12 AM
Puke
Dec 27, 2005 06:33 PM
