About the voltage drop from the grid heaters..cold starts.
Old Dec 27, 2005 | 06:07 PM
Puke's Avatar
I realize here in L.A. a cold morning is about 40 degrees (ha!!!).
But I notice that my voltage goes clear down to like 11 volts when I start it (and seems to stay at that voltage for a minute or 2) and slowly makes it's way back up to 14.2 taking at minimum 3 or 4 minutes. On a warm day, it get's back up to normal voltage quite quickly....I think less than 30 seconds.
Old Dec 27, 2005 | 06:29 PM
torquefan's Avatar
There are two of those heater grids, and each will draw approx. 120 amps. On the post heat cycle (engine running) the PCM will cycle those grids, one at a time, until the truck reaches about 20 mph, or the temp comes up over a certain amount. What you are seeing on the charge gauge is normal considering that large an electrical draw.
Old Dec 27, 2005 | 06:33 PM
graphitecumnz's Avatar
sounds normal... that's what mine does.
Shovelhead
63
Dec 16, 2025 08:28 PM
pmtg
Feb 10, 2015 07:00 AM
rollie
Jan 23, 2007 09:51 AM
cootz
Sep 27, 2006 10:17 PM
