Codes
Old Mar 19, 2003 | 08:33 AM
bkay's Avatar
Codes
Where do you check for codes and how do you read them. I know that they are shown at the odometer but how do you get them to show up?
Old Mar 19, 2003 | 10:05 AM
jec3's Avatar
Re:Codes
bkay - ignition key on, off; on, off; on, off; ON (basically 3 times) then look at your odometer the codes will appear (if any) the PDONE will appear meaning done. Any codes prefixed by a P are powertrain codes. There is another prefix but I can't remember it.<br><br>Hope this helps
Old Mar 19, 2003 | 10:20 AM
SjLingenfelter's Avatar
Re:Codes
If you could try to write the codes down and I could get them. Cause when I go to reprogram a chip it will bring up all the codes for it. and all the codes for the computer.
Old Mar 19, 2003 | 10:26 AM
KatDiesel's Avatar
Re:Codes
[quote author=SuperiorDiesel03 link=board=4;threadid=12470;start=0#117982 date=1048090808]<br>If you could try to write the codes down and I could get them. Cause when I go to reprogram a chip it will bring up all the codes for it. and all the codes for the computer.<br>[/quote]<br><br>This ain't a Ford. Don't work like that, unless your reprograming a ECM.
Old Mar 19, 2003 | 10:28 AM
KatDiesel's Avatar
Re:Codes
I don't believe the trick works on the 98 and 99 Dodge Cummins, can't remember if it works on 2000's or not. You could try it tho.<br><br>Key on, Key off, Key on, Key off, Key on........leaving it on and observing the odometer.
Old Mar 19, 2003 | 10:31 AM
Re:Codes
<br>This ain't a Ford. Don't work like that, unless your reprograming a ECM.<br>
<br>I know it aint a ford. But if he writes the codes down then I can go in on the chip computer which has all the codes for CTD DM PSD on it I can tell him what the codes mean .
Old Mar 19, 2003 | 10:34 AM
bkay's Avatar
Re:Codes
OK did that and nothing but milage. Does that mean that there aren't any codes being thrown?
Old Mar 19, 2003 | 10:46 AM
Re:Codes
Forgot to tell you. You have to do it 7 times. Thats when it cleans the computer and shows all the problem codes. SD03<br>
Old Mar 19, 2003 | 12:02 PM
bkay's Avatar
Re:Codes
OK did it 7 times no codes shown. Actually nothing but milage nothing different is that what is suppose to happen? I hate computerized crap.
Old Mar 19, 2003 | 12:23 PM
KatDiesel's Avatar
Re:Codes
[quote author=bkay link=board=4;threadid=12470;start=0#118012 date=1048096938]<br>OK did it 7 times no codes shown. Actually nothing but milage nothing different is that what is suppose to happen? I hate computerized crap.<br>[/quote]<br><br>It doesn't work for 98 to 99 trucks.
Old Mar 19, 2003 | 12:31 PM
bkay's Avatar
Re:Codes
Sooo that means I need access to a diagnostic computer?
Old Mar 19, 2003 | 01:29 PM
KatDiesel's Avatar
Re:Codes
[quote author=bkay link=board=4;threadid=12470;start=0#118023 date=1048098700]<br>Sooo that means I need access to a diagnostic computer?<br>[/quote]<br><br>Unfortuantly yes. I've heard some say AutoZone will scan for free? But not 100% positive.
Old Mar 19, 2003 | 01:48 PM
redruM Hauler's Avatar
Re:Codes
[quote author=bkay link=board=4;threadid=12470;start=0#118023 date=1048098700]<br>Sooo that means I need access to a diagnostic computer?<br>[/quote]<br><br><br>i dont know where Iola Tx is but if you are arround Dallas / Lewisville i have access to a diag comp and can run your codes for free (i have also heard AZ does it as well Free)<br>
Old Mar 19, 2003 | 01:56 PM
bkay's Avatar
Re:Codes
Little bit east of Bryan/College Station. Will the diag. comp tell if the sensors are out of whack, ie. MAP, CPS, AIT. Also would my EZ need to be diconnected to do a check?
Old Mar 19, 2003 | 03:46 PM
BigBlue's Avatar
Re:Codes
Don't know about the EZ but AutoZone does scan for free. My friend took his Stang there to have his Check Engine Light checked and the codes cleared (new cam kind of set it off ).
exwrestler
Feb 5, 2010 09:34 AM
sallyman1
Aug 26, 2008 06:20 PM
mbenedict
Jul 21, 2007 09:19 PM
StormTrooper
Mar 28, 2005 09:17 AM
