Codes 1682 and 1693
Old Jul 20, 2005 | 05:21 PM
B.A.Ram's Avatar
Codes 1682 and 1693
Looks like charging system voltage too low, which could have occured when my water pump locked up, the belt came off, therefore make the alternator gauage going to zero. As far as 1693 what is DTC detected in ECM or PCM?????????????What does that mean.
Old Jul 20, 2005 | 05:46 PM
phox_mulder's Avatar
Companion code.
Shows up in either the ECM or PCM saying there is a code in the other module.
Result of having two computers that don't communicate well with each other.
Gasser's only have the PCM, but us lucky Cummins owners get the ECM in addition to the PCM.
phox
Old Jul 20, 2005 | 06:33 PM
B.A.Ram's Avatar
so does is throw that companion code with every code that it throws?
Old Jul 20, 2005 | 08:34 PM
Not necessarily.
Sometimes it does, sometimes it doesn't.
I guess some codes are recognized by both modules, so the code isn't needed.
phox
southerman
Sep 27, 2011 08:25 PM
dltriolo
Feb 19, 2007 05:35 PM
bsummit
Feb 22, 2006 05:12 PM
CTD_Neil
Apr 25, 2005 09:23 PM
