clutch petal pressure
This evening when driving my buddies 01 with a 5spd, clutch lost pressure, sometimes i get a little back but not enough for the clutch to work. Limped it home just shifting no clutch so i know the clutch holds. Did the slave go out or what else could have happened. Thanks
I just had mine go out. You typically have an internal failure where the o-ring isn’t able to seal and you may never see a loss of fluid....Much like the hydraulics on a tractor where the boom will slowly fall over a given period of time. I noticed a very small amount of fluid on the firewall indicating a master failure.
Anyways, I definitely recommend doing the whole system (Dodge or SB) verse changing a piece (NAPA). I changed the whole system in less than an hour. Do it before your seal totally breaks.
