check valves?
Old Nov 7, 2008 | 11:26 PM
REDNECK-WELDING's Avatar
check valves?
tell me what you know about them? will they solve a hot hard start problem? do they do in the return line or before the IP? if i wanted to control the pump pressure would i use it? if not what could i use
Old Nov 8, 2008 | 04:28 PM
george7941's Avatar
You cannot use the check valve to control the pressure but you can use a pressure regulator like the Simflo to control the pressure. I very highly recommend installing a pressure regulator. It will greatly increase the life of a stock lift pump.
Old Nov 8, 2008 | 05:43 PM
i dont have a stock lift pump i have a high flow one put on the frame rail. i have 20psi at the IP pump and it makes the truck have hot hard start. whats the best inline regulator and are they preset or do i have to sdjust them. i have the bd max power? i think. they said it has a regulator built in but i think you need to take it apart and change things to adjust it
Old Nov 9, 2008 | 03:00 PM
george7941's Avatar
The Simflo regulator works well and I think it will easily handle 20psi. The Simflo can handle the flow from a Walbro 392 and they put out 60psi plus.
I bought mine from
http://www.wideopendiesel.com/page8.html
The Simflo regulator is adjusted by taking it apart, but it is easy to do.
Adam3291
May 2, 2008 10:08 PM
draskobnsf
May 30, 2007 05:23 PM
wadecool
Apr 1, 2007 09:34 AM
Blowndodge
Jul 11, 2005 09:29 AM
Gary C
Mar 15, 2004 02:53 PM
