Check valve for VP44
Old Jan 30, 2007 | 02:53 PM
2500Ram's Avatar
There has been a lot of talk about this check valve lately. Can anyone provide a link where to purchase one and a R and R of this valve? This seems to be fixing many failed VP's and fluctuating fuel pressure readings. Obviously the pumps are good and this simple $35 part is fixing the hard starts, no starts and fluctuation fuel pressure readings.
Thanks
Old Jan 30, 2007 | 06:34 PM
robert78.5's Avatar
I am having trouble starting truck when hot, I pulled check valve and I can blow through it with my lips, the book says 10 lbs is needed, I guess I found my problem.....I hope....
Old Jan 30, 2007 | 06:54 PM
linetrash75's Avatar
I completely gutted the check vavle at one point. It did make hard starts after setting 10 mins or longer. I could tell no difference in fuel pressure at all.
jed
Old Jan 30, 2007 | 09:12 PM
Tate's Avatar
Best place to get it is from Cummins. Dealer wants twice as much for it. Expensive shipping, I guess.
There is an internal pump inside the VP, so the fuel isn't going to freely flow from supply to return line, which is why fuel pressure isn't affected by a bad overflow, unlike the 12v.
Old Feb 3, 2007 | 11:57 AM
robert78.5's Avatar
I changed my check valve this morning and now when I shut off engine, the fuel pressure gauge takes about 45 seconds to drop to zero, unlike before it dropped to zero as soon as engine was shut off. I am going to hit the highway and warm it up and see if she will start when warm now.
Old Feb 3, 2007 | 03:19 PM
cLAYH's Avatar
Hmm I've noticed that mine sometimes takes a 2nd hit of the key to go, most often noticed when I turn it off at the drivethru so I can place my order.
How do you get to this valve?
Old Feb 3, 2007 | 05:03 PM
Tate's Avatar
Its just ahead of the supply line. Its the banjo bolt in the return line. 19mm I think it is.
Old Feb 3, 2007 | 05:24 PM
robert78.5's Avatar
Yes I think I fixed my problem. stopped about six times this afternoon for different time spans ranging from 1 minute to one hour and started every time right away.
Old Feb 4, 2007 | 11:14 AM
slowflyer2112's Avatar
VP lessons:
I lost vp in Texas in Nov. 05 and truck did not run right since. Took vp out and sent it back to II for testing, checked out perfect, I had them return it with new check valve and now the truck runs correct.
At 1900 rpms truck would start to vibrate and would get worse all the way 3200
If the tranny was in lock up it was really bad, EGTs were very hot and power was way down at upper rpms.
What happens is that as your rpms go up the pistons in the pump get incomplete filling of fuel and so each cylinder gets a different fuel charge (vibration) and the advance piston gets an incomplete charge and does not advance the timing (heat) and last but not least when you shut the truck down it may be difficult to start(no fuel in pump it bled down)
The vp has its own pump built in and it pushes the fuel into the cylinders of the pump. If the check valve on the outlet is not working properly it may have problems.
I was also told that different pumps react differently and they don't know why?
The person who installed my pump had used my old check valve on my new pump and thats what caused all of my problems it cost me 300.00 to learn this. The interesting thing about it all is that the old vp had none of these problems it failed because some idiot dumped a load of unleaded fuel in the diesel tank at the station .
Hope this helps.
Mark
My wife say's that if didn't have bad luck I wouldn't have any luck! I'll take no luck, Please!
Rampage1967
Jun 2, 2015 12:22 PM
tpitt
Sep 4, 2012 06:41 PM
nitrousn
Jul 8, 2010 03:11 PM
Smokin'02
Feb 25, 2007 08:39 PM
Timmay2
25
Feb 12, 2006 01:00 AM
