Changing shift points
Under heavy throttle my tranny shifts too late out of 1st gear and under light throttle shifts too early from 2nd to 3rd. Can I change the shift points to correct this?
Mark
Mark
not an easy fix for this. if you subtract throttle pressure to make the 1-2 sooner than it will make the 2-3 sooner also. and it will do the opposit by adding TV. there is NOT an easy way to set light throttle shift points without changing full throttle points also. you might give a call to one of the tranny vendors and see if there VB will fix this. without a VB test machine you are just wasting your time.
bill
bill
CDoskocil9
Jan 21, 2009 05:05 PM
Dodgezilla
May 30, 2004 03:46 AM
cad14man
Oct 22, 2003 05:44 PM
